T Track Bolts Question
Forum topic by copcarcollector posted 201 days ago 621 views 0 times favorited 4 replies Add to Favorites Watch
View copcarcollector's profile
copcarcollector
57 posts in 289 days
201 days ago
Newbie here, forgive me!!
I have added some Rockler T Trak to a countertop / workbench I am making. Honestly I just wanted to mess around with the T Track, hold downs etc.
My question is, does anyone make a bolt for the T Track that you can insert in the middle of a run of track, then turn 1/4 turn, and clamp down with the knob or jig or whatever. I figured the T Track bolts worked this way, but the bolts I have don’t – I have to slide the bolt in from one end, the run it all the way down the track to wherever I want the clamp. I have a 16 foot run of track, maybe I should have investigated how T Track works first!
Any help or insight appreciated. When I was working in theatre lighting we had basically the same thing upside down on the ceiling, but we could slide the bolt (nut technically) in the track, then make a 1/4 turn and it would engage the rails, then tighten it down. I can’t recall what that track was called——Ahh – Unistrut.
Jef
If I have not explained what I thought the bolts would do, let me know.
View Loren's profile
4896 posts in 1819 days
#1 posted 201 days ago
You want a drop-in nut or drop-in stud. You can get them
for 80-20 type profiles. T-track is typically shallower,
but you can grind the stud head down.
For that matter carriage bolts could be ground down
to function as drop-ins.
View johnLT's profile
johnLT
12 posts in 309 days
#2 posted 201 days ago
Loren, thanks for the response. Never thought of grinding down the head. Don’t have to buy anything to solve this problem!!!
View FirehouseWoodworking's profile
568 posts in 1444 days
#3 posted 201 days ago
You may also be able to use toilet flange bolts. They have the two sides of the head flat rather than a round head. They are designed to do exactly what you want to do, except they are used on the toilet floor flange. they should work in T-Trac.
Cheers!
-- Dave; Lansing, Kansas
View cutworm's profile
cutworm
685 posts in 965 days
#4 posted 201 days ago
I did that with carriage bolts. I ground 2 sides flat. At your local ACE Hardware they have a section for specialty bolts. My bet is that they have them but it will cost you.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
