| Forum topic by DavidBethune | posted 200 days ago | 1257 views | 0 times favorited | 8 replies | ![]() |
200 days ago |
Topic tags/keywords: question I have just purchased a 2 1/2 hp DC Treadmill Motor to convert my Beaver Lathe to variable speed. This is Harbour Freights unit: Harbour Freights Router Speed Control I’d appreciate any suggestions |
8 replies so far
#1 posted 200 days ago |
I wouldn’t. The controller from the treadmill will most likely be a PWM motor controller which should give you a lot more low end torque than the resistor speed controller. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#2 posted 200 days ago |
I agree with David Kirtley. Use the treadmill speed controller. -- Love thy neighbour as thyself |
#3 posted 200 days ago |
If that DC motor isn’t series wound, a small rheostat in the field will control it. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#4 posted 200 days ago |
Here is a great link for converting lathes for variable speed using a treadmill motor. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#5 posted 200 days ago |
Thanks for the comments. I guess I’ll try the Treadmill Board but it’s bigger than I wanted to use. Topamax: I’m not sure if the DC motor is series wound or not? I’m no electrical whiz.. that’s for darn sure. I know how to plug stuff in..LOL that’s about the extent of it. This will be a learning experience for sure.. |
#6 posted 200 days ago |
This is impossible to say without knowing exactly what motor you have. So all my statements are general and subject to exactly what motor you have. In general, the DC motors for treadmills that I have run into are permanent magnet DC motors. The application is just not well-suited to universal motors. The router speed control from HF that you reference is not suited to DC motor control. It actually provides chopped AC voltage to a universal motor. Even if you have a universal motor, you probably do not want to run the simple HF router speed control on it. You will get from 2X to 4X the low speed torque with a PWM DC speed control than you will with a chopped AC speed control on the same universal motor. Now, PWM DC variable speed controllers are more complicated than simple chopped AC speed controllers and that probably explains the differences in size between the two controllers you mentioned. Topamax’s statement is void. You probably either have a universal motor, which are always series wound or they wouldn’t run on AC/DC, or a permanent magnet motor, in which case there is no field coil – the magnets provide the magnetic field – and you cannot vary field strength with a rheostat. -- "Find out what you cannot do and then go do it!" |
#7 posted 200 days ago |
If that is a permanent magnet or series motor, I am definitely voided out;-)) You need 2 big wires and 2 little wire sticking out of the motor to do what I suggested. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#8 posted 200 days ago |
David the HF control states it is 15 amp max, I have never seen a 2-1/2 hp motor that would be that low on -- As ever, Gus-the 74 yr young apprentice carpenter |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15790 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
