Can somenone teach me how to turn a wooden box?
Forum topic by Christopher posted 112 days ago 209 views 0 times favorited 11 replies Add to Favorites
View Christopher's profile
Christopher
199 posts in 457 days
112 days ago
I have seen so many turned boxes and i think thay are beautiful but I can’t figure out out how turn one. I don’t have a 4-jaw chuck but I do have a faceplate for turning. I need someone to describe how they do it step by step and pictures would be fantastic if it can be done! As usual thank you guys, I know I can count on Lumberjocks to mentor me!!
-- Sometimes when I am building something and it is out of square, I just bend my square.
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
277 posts in 134 days
111 days ago
Christopher,
check this PDF out, though he does use a chuck. I am not sure how you would do one without a chuck since you need to hold the work with the other end free to work. Either a chuck or vacuum chuck.
http://www.woodturnersguild.com/mambo/index.php?option=com_docman&task=docclick&Itemid=52&bid=13&limitstart=0&limit=5
-- Rich, WNY, www.nyrockingchairs.com
Douglas Bordner
2732 posts in 600 days
111 days ago
Hey Rich. Thanks for the link.
Dick, & Barb Cain
5384 posts in 836 days
111 days ago
This is a pretty good tutorial on Fine woodworking.
I’m not sure if you have to be a member though, but give it a try.
NY_Rocking_Chairs
111 days ago
I think you have to be a member, it took me to the login page.
Dick, & Barb Cain
111 days ago
I’m sorry it didn’t work, here’s a free video site for wood turners at
WOOD Magazine.
Click on the woodturning category.
They show how to turn a toothpick dispenser.
Christopher
111 days ago
I appreciate it Dick!. I will check that link out in a few. i have to deliver a restore job I did and I am a littlle nervous as it’s late!
6716 posts in 388 days
111 days ago
Christopher, I don’t know but someone may have done a video on the LJ site
http://lumberjocks.com/videos
View Sandyj's profile
Sandyj
2 posts in 111 days
110 days ago
Hi there I have turned a wooden box on a 4 jaw chuck and thinking about it, you will need to support the wood quite firmly. Do you have a screw mount? This may be possible. Or screw to you face plate.
The following is my recollection of box making on a lathe. Watch for uneveness with the wood as the mount may not be very strong !
Here goes – Please be safe – By mounting in the screw mount and the tail stock you can rough out the main shape. Then decide where the lid will be (at the tailstock end of course) and shape it, you come in (rebate) for about 3/8” and at the base of the lid (the head stock end of the rebate) part off. Then hollow out the box. The inner dimension of the box would be the outer dimension of the lid’s rebate. Hollow down to about 1/2” before the screw mount. Sand inside – I use a dowel – cut up the length by about 1 inch and fold sand paper in the slot. Place lid on box and re-introduce the tail stock and finish off.
If you have any concerns with this process please stop. Like I said I have only done this in a 4 jaw chuck but the theory should be the same if you can mount the wood securely. I have not used a faceplate for turning.
Regards
-- Sandy in NZ
View scottb's profile
scottb
3060 posts in 864 days
110 days ago
I think Richard Raffan did a demo in a recent years FWW mag. He also has a bazillion (it’s a real number) books out there… next time you’re by a book store just spend a while browsing. that is, if our fellow LJ’s haven’t dug up enough links and tutorials by then. I’m sure a 4 jaw chuck would make things easier, but you can certainly glue or tape your blank to a faceplate, and get most of the roughing done between centers.
-- I am always doing what I cannot do yet, in order to learn how to do it. - Pablo Picasso -- http://snbcreative.wordpress.com/
View lew's profile
lew
1751 posts in 292 days
110 days ago
Here is a link to some tutorials and projects
http://www.woodturningonline.com/Turning/Projects/boxes.html
Dick, & Barb Cain
110 days ago
I think you can do real well by just using a faceplate, & center screw.
I’ve done most of my turning, using a faceplate.
I recently bought a chuck, & I’m having to learn all over again.
Bookmark And Share This Page
