how should I size tenons?
Forum topic by JesseTutt posted 11-03-2012 03:43 AM 1433 views 0 times favorited 4 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2074 days
11-03-2012 03:43 AM
Topic tags/keywords: question mortise and tenon sizing a tenon
I am going to build a new workbench this weekend. I plan to use existing 2×4s that I have on my wood rack. I need to get rid of them and make space for “real” wood. I was going to mortise and tenon joinery. My plan calls for through tenons on the horizontal rails connecting the front left leg to the rear left leg. The top joint will actually be a bridal joint and the lower a through tenon.
Assuming that the 2×4 is actually 1.5×3.5 I am planning on making a 1×3 tenon.
My question is “Are there any rules on how to size a tenon?”
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#1 posted 11-03-2012 03:46 AM
Tenons are usually 1/3 the thickness of its stock. IE 1/2 tenon for a 1-1/2” board, although a little fatter is also acceptable. I usually plan for mortise sizes that correspond to my hollow chisel sizes 1/4”, 5/16”, 3/8”, or 1/2”.
View John's profile
John
47 posts in 2037 days
#2 posted 11-03-2012 05:53 AM
The 1/3 rule applies more to the piece that gets the mortise. ie, if you’re joining two pieces of 3/4” stock, you’d make the joint parts 1/4” thick so you leave enough meat around the mortise that it doesn’t split or blow out. If you don’t have to worry about the mortised piece, then the bigger the tenon, the better, as long as you leave enough shoulder to firmly register the joint.
So for a 2×4 going into a mortised 4×4, a 1×3 tenon is fine. Same if it’s going into the wide side of a 2×4.
View Woodknack's profile
Woodknack
11479 posts in 2344 days
#3 posted 11-03-2012 06:15 AM
Hmm, I’ve always made my mortises 1/2 the stock (or closest chisel size), so a 3/8 mortise in 3/4 stock. Maybe I’ve been making them too big?
View cutworm's profile
cutworm
1075 posts in 2757 days
#4 posted 11-03-2012 10:56 AM
I’m told that the tenon length should be twice the tenon thickness.
-- Steve - "Never Give Up"
