| Forum topic by shelly_b | posted 200 days ago | 901 views | 0 times favorited | 19 replies | ![]() |
200 days ago |
I recently bought some scrapers and while they seem to be faster than using a random orbital, the sand paper seemed to leave a smoother (feeling) surface, so I sanded after I sraped. What are some of the pros and cons of finishing with each, and which do you prefer? I was using oak, if that makes a difference. |
19 replies so far
#1 posted 200 days ago |
The surface feels smooth after sanding because you are just knocking the fibers down. It abrades. With a scraper, you are taking the fibers clean off. Touching it, it’s like when you rub your head after a buzz cut…you feel the ends of the fibers. But that does not mean its not smooth (or even)...it just means that sandpaper makes it feel pillowy because you aren’t feeling the ends of the fibers. I have gotten to the point where I save my sandpaper for finish work. My scrapers do the prep-work. It makes for more consistent finishes, IMO. With sandpaper, there’s any number of swirls and scratches that I inevitably impart to the work, including rounding over corners when I don’t want to. “Smooth” occurs after the first finish coat, when the wood is sealed. So, feeling the wood before finishing doesn’t mean anything. Prep-work should focus on getting rid of tool marks, not “smoothness.” This is why there’s really no reason to sand past 120 grit or so when prepping for finish. -- jay, www.allaboutastro.com |
#2 posted 200 days ago |
Shelly the biggest con of sandpaper that drives me to stick with my scrapers or smooth planes is dust. I cannot stand the mess plus I do not like to wear any type of mask when I am working and I am sure any wood dust is going to be detrimental to good lung health. With scrapers and planes, no dust at least if the tools are tuned right). -- Mike |
#3 posted 200 days ago |
Shelly, Here are a couple of good articles on Scrapers, use and sharpening, you may find interesting. http://woodgears.ca/scraper/index.html Work Safely and have Fun. – Grandpa Len. -- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana. |
#4 posted 200 days ago |
Scrapers are the best, sandpaper for those areas you can’t get to with a scraper -- Norman |
#5 posted 200 days ago |
You can sharpen scrapers in different ways to get different |
#6 posted 196 days ago |
Thanks everyone. Im gonna have to make some test peices with sanding and scraping and then finish them and see how they come out |
#7 posted 196 days ago |
I would use a scraper first then sandpaper. Using a scraper is faster and save money on sandpaper. |
#8 posted 194 days ago |
I got tired of sharpening scrapers, so I use pieces of fresh cut window glass. Works great. |
#9 posted 194 days ago |
If you get really good at scrapers, I find that an old chisel with a burnished edge is great for glue squeeze out in corners… but the hands down best reason I prefer scrapers over sand paper… I have 10 scrapers (half of which are always waiting to be sharpened, lol)... but I have spent a total of less than $30 over the last decade… there is no way of knowing how much $$$$$ on sand paper. -- ~ Eric P Jorgenson: Jorgenson Design |
#10 posted 194 days ago |
Here is a reasonable description of the planing, scraping, sanding process by Schwarz and Charles H. Hayward: -- Scott |
#11 posted 193 days ago |
I got tired of sharpening scrapers, so I use pieces of fresh cut window glass. Works great. Phew, I don’t know about that. Do you wear chain mail gloves? -- LAS, http://www.abettersign.com |
#12 posted 193 days ago |
Lol Luke, I thought the same thing! Shelly; I’ve used scrapers on a couple of projects, they are certainly quicker than sanding, but I still finish sand the surface to 220. I wish I was proficient enough and patient enough to use scrapers and planes exclusively for my projects, but the endless sharpening that comes with using scrapers gets old fast. -- Rob, Sault Ste. Marie, Ontario |
#13 posted 193 days ago |
yeah, I need to look into how to sharpen them correctly lol… |
#14 posted 193 days ago |
It takes me about 2 minutes to sharpen a scraper. And that’s with one hand tied behind my back. That said, right now my main scraper needs some sharpening and I’ve currently gone longer than I should have. It’s amazing how lazy I get sometimes. -- jay, www.allaboutastro.com |
#15 posted 193 days ago |
Thank you to Cosmicsniper for the very helpful mini-tutorial! -- Paul, Clinton, NC |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3547 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
