| Forum topic by Surfside | posted 197 days ago | 724 views | 1 time favorited | 28 replies | ![]() |
197 days ago |
There are different types of band saw blades and it has different uses or respective uses. What type of band saw blade are you using now? -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
28 replies so far
#1 posted 197 days ago |
All from Suffolk Machinery. 1/8 for scrolling, 3/16 for band saw boxes, 1/4 not used often and 1/2 for resawing. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#2 posted 197 days ago |
Pretty cool :) Thanks for that . Since when did you get your 10” shopsmith? -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#3 posted 197 days ago |
At the moment I have a Lenox Diemaster 2 mounted, I’ve been doing some resawing. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#4 posted 197 days ago |
That’s HSS . ? -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#5 posted 197 days ago |
Amazon has a 3 pack of Olsen for $52 that i jus tpicked up. One for scrolling, one for radius cuts, and one for resawing come in the package. I havent tried then out yet so i cant report as to the quality but the the price is right. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#6 posted 197 days ago |
Timberwolf from Suffolk Machinery. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#7 posted 197 days ago |
3/4” by 131.5” 2-3 tpi (teeth per inch) Timber Wolf blade at the moment. Looking forward to trying the WoodSlicer. -- Jesse, Saint Louis, Missouri |
#8 posted 197 days ago |
Did you mean Olson? -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#9 posted 197 days ago |
1/4” 8 tpi, 3/8” 6 tpi, 1/2” 3 tpi. 93 1/2” for the Grizz. About $7.00 each. -- bill@magraphics.us |
#10 posted 197 days ago |
I have 201 Series Haltbar carbon blade, which is best for cutting hard woods . -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#11 posted 197 days ago |
That Olson set in 93-1/2” (for my 14” Delta) is coming up at $46.90 and with Prime, no shipping :) |
#12 posted 197 days ago |
I Buy from a company called BC Saw and tool. They are in Canada – and not British Columbia, as the BC might imply, they are actually in Toronto. Our guild did a mass buy and the cost was around 7 dollars per blade. They also do sharpening. If you are just buying a couple for yourself, they still were running ~ I use 1/2 inch 3 TPI for 97% of all the cuts. then I have a 3/16 blade for scrolling if needed. -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#13 posted 197 days ago |
lennox from iturra design. seriously old school guy who really knows how to weld band saw blades. -- there's a solution to every problem.......you just have to be willing to find it. |
#14 posted 197 days ago |
Timberwolf and Woodslicer from Highland Hardware. -- Roger M, Aiken, SC |
#15 posted 197 days ago |
I have 3 Craftsman blades and a Woodslicer. The Craftsman blades have worked just fine for what I do, and the Woodslicer rules in ways that should be illegal. Rich;) -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
