Cutting a circle on a Router Table?
Forum topic by Peteyb posted 11-01-2012 08:33 PM 4236 views 0 times favorited 6 replies Add to Favorites Watch
View Peteyb's profile
Peteyb
131 posts in 2577 days
11-01-2012 08:33 PM
I am trying to figure out how to cut a circle on the inside of 12”x12” of hardboard. I was wanting to do this on my router table but afraid that when the circle is cut one of the pieces will go flying out of control. Any help?
View Surfside's profile
Surfside
3389 posts in 2195 days
#1 posted 11-01-2012 08:52 PM
Try watching THIS
Hope this will help you . :)
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View oscaro928's profile
oscaro928
9 posts in 2054 days
#2 posted 11-01-2012 10:23 PM
That was really useful, thanks. I have to try that on my table.
Oscar
Surfside
#3 posted 11-02-2012 01:28 PM
You’re welcome.
Peteyb – try doing that too :)
Peteyb
#4 posted 11-02-2012 03:11 PM
Surfside just got on this morning to look at this. I think that this should work for what I am looking to do I just need to figure out out to make that ruler he has in his miter slot. Thanks for the help I have been looking at a lot of circle jigs but never found this one.
View kizerpea's profile
kizerpea
774 posts in 2389 days
#5 posted 11-03-2012 01:28 PM
That works…thats how i made some 32” circles…with out the marking…. i just put a stop in the track from the other end ..held with a clamp so i could adjust ..then just put your work on the pin an slide it into the bit ..just keep adjusting your stop until its right..then every circle will b the same..
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View Woodknack's profile
Woodknack
11758 posts in 2401 days
#6 posted 11-04-2012 09:31 AM
Peteyb, couple of ways to keep control of the outside piece:
-leave a few spots uncut and finish them by hand
-cut all but 1/32nd through and then finish by hand
-use double sided tape to fasten both inside and outside to a sacrificial board that you cut into but not through
