4212 PorterCable DoveTail Jig-easy to learn OR not?
Forum topic by steve6678 posted 11-01-2012 02:09 AM 1073 views 0 times favorited 8 replies Add to Favorites Watch
View steve6678's profile
steve6678
438 posts in 2061 days
11-01-2012 02:09 AM
New dovetail Jig…unfamiliar with it…
Any GOOD, USEFUL, UN-COMPLICATED…
advise?
-- Steve - Dust sucks!
8 replies so far
View ShaneA's profile
ShaneA
6929 posts in 2599 days
#1 posted 11-01-2012 02:16 AM
Use plenty of scrap stock milled to same sizes you will be using for your finished project, get a dialed in fit/adjustments, then bang em out.
View cabmaker's profile
cabmaker
1731 posts in 2809 days
#2 posted 11-01-2012 02:17 AM
very easy
View NiteWalker's profile
NiteWalker
2737 posts in 2577 days
#3 posted 11-01-2012 02:35 AM
Very easy; here's a video.
16274 posts in 4219 days
#4 posted 11-01-2012 01:48 PM
The two keys are:
1. Play around with it so you understand the effect of different adjustments.
2. Like Shane said, use scrap to get everything dialed in just right before you start cutting on your good stock.
Oh, and…..
3. Be sure to stop routing when you get to the last slot on the left. A sharp dovetail bit cuts aluminum rather nicely. (DAMHIKT)
View harley04's profile
harley04
27 posts in 2767 days
#5 posted 11-01-2012 01:57 PM
I have had mine about 2 weeks and can confirm, use lots of scrap until it is dialed in. After that go with it. The online video Nitewalker mentioned is helpful but you need to watch it a couple times as the camera work is not great
View Bill White's profile
Bill White
4932 posts in 3961 days
#6 posted 11-01-2012 03:32 PM
I have the 4210 (doesn’t do thru DTs). Did 1 test for the half blind DTs, got it set, works good.
Wish now that I had the thru DT capabilities, but I’ll just buy the needed parts.
Bill
-- bill@magraphics.us
View ajosephg's profile
ajosephg
1880 posts in 3561 days
#7 posted 11-01-2012 05:32 PM
”3. Be sure to stop routing when you get to the last slot on the left. A sharp dovetail bit cuts aluminum rather nicely.”
I second that. Carbide box joint bits also cut into steel off set stops.
-- Joe
steve6678
#8 posted 11-01-2012 07:34 PM
Ha, I hear ya…thanks all.
