What am I missing on my router table?
Forum topic by mdp posted 10-31-2012 11:31 PM 1196 views 0 times favorited 6 replies Add to Favorites Watch
View mdp's profile
mdp
16 posts in 3493 days
10-31-2012 11:31 PM
I bought a 31/4” panel raising bit to use in my router table… But when I mounted it the big Triton router, the base of the router is too small for the bit to pass through… What brand of router would work for this?
-- Michael
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3423 days
#1 posted 10-31-2012 11:48 PM
I have the same Triton router and I have it mounted in my table. You should be able to take the base plate off, remount it in the table plate and then there is plenty of space for the large bits.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View bondogaposis's profile
bondogaposis
5155 posts in 2591 days
#2 posted 10-31-2012 11:49 PM
You have to make another base plate w/ a larger hole. This is a common thing and not too hard. Are you using it on a router table?
-- Bondo Gaposis
RetiredCoastie
#3 posted 10-31-2012 11:56 PM
When mounting the Triton in a router table your supposed to remove the factory installed base plate. Then the limiting factor would be the opening in the router table mounting plate. I just measured the opening in my table plate and it’s 3-7/16”
View mdp's profile
mdp
#4 posted 11-01-2012 03:20 AM
Yes I removed the plastic base plate… But the opening in thge router base is only 3 1/8”... the mounting plate is fine, it’s the base of the router…
-- Michael
View NiteWalker's profile
NiteWalker
2738 posts in 2817 days
#5 posted 11-01-2012 03:36 AM
My guess is you have the 2 1/4 HP version of the triton, in which case I’d not spin a panel raiser in it anyway.
A vertical panel raiser can be spun easily in that router.
View ducky911's profile
ducky911
237 posts in 3029 days
#6 posted 11-01-2012 10:51 PM
why don’t you add some 3/4 plywood on the top with a bigger hole?
