Driving a Drum Sander
Forum topic by captfoss posted 10-31-2012 03:09 PM 2834 views 0 times favorited 18 replies Add to Favorites Watch
View captfoss's profile
captfoss
20 posts in 2126 days
10-31-2012 03:09 PM
I’ve seen various designs for drum sanders, either of the v or thickness variety, which are shop-build and call for belt-driven motors that range from as low as 1/4 HP all the way up to 1 HP, which I price anywhere from $60+ just for the motor.
Most of the designs I’ve seen seem to descend from this project:
http://www.rockslide.org/drum%20sander.html
Which uses a 1 HP motor to drive what appears to be a 3” diameter, 14” long drum.
I was wanting to get people’s opinion on doing a similar drum thickness sander, but driving the drum directly with a cheap drill from Harbor Freight. Specifically,
http://www.harborfreight.com/power-tools/drivers/1-2-half-inch-heavy-duty-variable-speed-reversible-drill-3273.html
It’s rated at 1080 watts, which if I’m doing my calculations correctly, means it’s a 1.4 HP motor with full-speed torque rated at ~6 foot pounds.
The math all adds up that the drill should have more power than the 1 HP motor used in the original project, but I assume I’m misunderstanding something about how motors work.
Advice would be great.
18 replies so far
View Bill White's profile
Bill White
4859 posts in 3867 days
#1 posted 10-31-2012 03:25 PM
The drill HP ratings are established at full speed, no load, just before the motor explodes. The drill is not designed for continuous duty either.
I wouldn’t bother tryin’ to use a drill to power a drum sander. (But what do I know?)
Bill
-- bill@magraphics.us
View crank49's profile
crank49
4029 posts in 2877 days
#2 posted 10-31-2012 03:40 PM
That HF tool is typical of their offerings. Either they do not know what the ratings are or they intentionally mislead you.
The specs in the HF link say 6.3 amps, 120 volts, 1080 watts. One of these numbers has to be incorrect.
Amps X Volts = Watts
6.3A X 120V = 756W
OR
1080W / 120V = 9A
On the other hand, in terms of driving the drum with a drill; I wouldn’t do it.
The drill is a universal or series wound motor with brushes and sleeve bearings and a gear reducer.
It would not last very long running continuously. It’s designed for intermittent use.
And the gear will be noisy and rob power through efficiency issues and waste heat generation.
A better choice for a cheap motor is a re-purposed bench grinder.
View Swyftfeet's profile
Swyftfeet
170 posts in 2078 days
#3 posted 10-31-2012 03:50 PM
What Bill said. Those figures on the box or in the add are specific ideal points in time(for the rating) that hardly demonstrate actual use conditions. You would thermally overload a drill in very little time( a span of seconds) with a consistent full load like that.
Link
-- Brian
View jap's profile
jap
1251 posts in 1961 days
#4 posted 10-31-2012 03:54 PM
agrees^with all the above
-- Joel
View DIYaholic's profile
DIYaholic
19538 posts in 2581 days
#5 posted 10-31-2012 04:05 PM
There is no reason to pay full retail price for a motor, you can find a used motor in a free washing machine, or anything cheap on CL.
captfoss
#6 posted 10-31-2012 04:10 PM
Ok then.
All of the bench grinders (6/5/3”) on their site are rated at 3450 rpm, and commercial drum sanders are rated at approximately half of that. Is there a cheap solution to that problem?
View Gene Howe's profile
Gene Howe
10136 posts in 3335 days
#7 posted 10-31-2012 04:45 PM
”All of the bench grinders (6/5/3”) on their site are rated at 3450 rpm, and commercial drum sanders are rated at approximately half of that. Is there a cheap solution to that problem?
Pulleys, but someone else will need to provide info on sizes and ratios.
crank49
#8 posted 10-31-2012 05:22 PM
Look for a good old 8” or 10” grinder. Will usually be 3/4 hp or better. Might be 1800 RPM
If you need to reduce speed with pulleys, the speed difference will be the same as the pulley diameter ratio.
IE. 3400 RPM motor with 2” pulley driving a Drum with a 4” pulley. the Drum will be turning at 1700 RPM.
Swyftfeet
#9 posted 10-31-2012 05:40 PM
and double the torque!
-- Brian
View dbhost's profile
dbhost
5686 posts in 3138 days
#10 posted 10-31-2012 05:45 PM
Grab a dedicated proper motor. I see 1.5HP table saw type motors going cheap on CL pretty often.
I picked up a HF 1.5 HP motor. I have hooked it up to my drum, and as a temp test rig bolted it to a simply test jig, no adjustments, shoved 3/4” stock through it with no stalling, no burning. Took 1/8” off the stock no problem…
I am using a 24” wide drum.
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View Loren's profile
9963 posts in 3554 days
#11 posted 10-31-2012 06:05 PM
For a drum thicknesser you want the strongest motor
you can get your hands on and run on the wiring you
have.
I recommend at least 1.5 hp.
captfoss
#12 posted 10-31-2012 07:07 PM
What about driving it with a 1.5 HP variable-speed router set to the lowest setting (~10,000 rpms) and then further speed reduced 1:5 or so?
#13 posted 10-31-2012 07:12 PM
You’ll smoke the router.
captfoss
#14 posted 10-31-2012 07:26 PM
Ok, so how can you tell whether or not a particular motor is designed to be run for extended periods of time under load?
View HalDougherty's profile
HalDougherty
1820 posts in 3143 days
#15 posted 10-31-2012 07:42 PM
I bought a cheep lathe from someone on Craig’s List and I use it as the base for my Drum Sander. I made two plugs to fit into the ends of a 3” piece of PVC. Then I made MDF circles that fill the tube. There’s a 1/2 inch threaded rod in the center and the MDF circles are glued together. There isn’t any flex and I made it to give me 12” of sanding area. Hose clamps hold the strip of sandpaper to the tube and two pieces of MDF hinged together with a threaded rod of elevation adjustment make up the rest of the sander.
Shipwright made a much better version using his Shopsmith for the base. Mine works just like it, but mine looks like it was cobbled together by a couple of blind monkeys compared to his.
-- Hal, Tennessee http://www.first285.com
