Drum sander and endgrain Purpleheart
Forum topic by don1960 posted 10-31-2012 03:31 AM 3035 views 0 times favorited 16 replies Add to Favorites Watch
View don1960's profile
don1960
227 posts in 2590 days
10-31-2012 03:31 AM
I finally got my 16-32 drum sander. Nice!!
Anyway, it does a wonderful job on facegrain anything I’ve thrown at it. Endgrain, well, that’s another story. Here’s the deal:
I just finished gluing up an endgrain Maple/Purpleheart cutting board. Thought great, now I don’t have to spend 237.5 hours sanding the thing flat. Seems the endgrain purpleheart had other plans. :-)
Run it thru fast, slow, while standing on one foot, with the garage door open, with the garage door closed, no joy. :-) Even with the slightest, slightest cut, it burns. Tried everything from 180, 120, all the way down to 80 grit paper. I’m talking about just trying to take a few thousandths off at a pass, even.
So, anyone who has tried this, is there some magical combination of speed/paper/cut depth that will work for endgrain purpleheart??
-- -- Don from PA
16 replies so far
View longgone's profile
longgone
5688 posts in 3212 days
#1 posted 10-31-2012 04:11 AM
I have a jet drum sander and have also discovered that some woods just refuse to go through my machine without burning or gumming up the sandpaper regardless of how miniscule of an amount I try to sand. This will also happen on facegrain. Bloodwood, cocobolo, sinker cypress are a few that come to mind.
View tomd's profile
tomd
2125 posts in 3673 days
#2 posted 10-31-2012 04:29 AM
Purpleheart and Bloodwood ruin my belts in no time, too much oil in these woods.
-- Tom D
View PRGDesigns's profile
PRGDesigns
235 posts in 2216 days
#3 posted 10-31-2012 04:55 AM
Have you thought about an even coarser grit just to get it flat? I know the Supermax guy recommended the coarser grits, i.e. 36 grit or 50 grit, on some of the oilier woods. 80 grit burns PH with my drum sander and I am heading to the coarser grits to see if it helps. I dimensioned some end grain cutting boards recently, although none of them had PH in them, with both 36 grit and 80 grit. While the 36 grit showed slight burning on the actual wood, the sandpaper itself did not have any of the tell tale signs of burning like I experienced with 80 grit on the same type cutting boards. I was also able to increase productivity with the coarser grits by being able to stand on both feet and I could hold my mouth any way I wanted to. Just a thought.
-- They call me Mr. Silly
View Manitario's profile
Manitario
2603 posts in 2786 days
#4 posted 10-31-2012 05:05 AM
Do you have a planer? I used my planer on my purpleheart cutting board…supposed to be a no-no on endgrain but if you take very slight passes it will work.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3086 days
#5 posted 10-31-2012 05:48 AM
I’ve used my 16/32 drum sander on at least 10 boards with purpleheart with great success. I use 180 grit. I adjust untill I just start to hear the paper making contact and then I only adjust the height 1/8 th of a turn after making 2 passes on each side of the board. Before I even think of using the drum sander I make sure there is no glue visible on the board. If when you feed your board into the sander and you hear the machine load up then your height is too aggresive and your feed rate is too fast. After all is smooth and level I switch to my ROS and work up to 400 grit.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
don1960
#6 posted 10-31-2012 08:31 AM
@prgdesigns: I had considered coarser grits, but I think I’ll just use a router sled to flatten instead since anything coarser than the 80 will leave at least as many lines as the router.
Rob, I hesitate to use the planer, since even if it does work, it leaves tearout that I got the drum sander to (mostly) eliminate. At least, my planer does, even on the purpleheart facegrain sometimes.
@retiredcoastie: yea, all the visible glue is/was gone, and I don’t think it’s possible to take smaller passes than I did.
To all: thanks for the responses. It seems for the most part that certain woods may just not work well. The hard maple sections of the board, even thought they are just about as hard as the purpleheart, had no problem going thru the sander.
If I come up with something that works, I’ll be sure to pass it along.
I suppose I could always take it into work, throw it down on a large surface grinder, put on an 80 grit white wheel and flatten it to ±.001”...... but that’s cheating :-)
Don
-- -- Don from PA
View AandCstyle's profile
AandCstyle
2977 posts in 2160 days
#7 posted 10-31-2012 02:01 PM
I have found that I don’t get burning if I let the wood cool after making a couple very light (less than 1/128”) passes through the sander. I either sand another board or do something else for a few minutes. Feel the surface of your board and wait if it is warm. HTH
-- Art
don1960
#8 posted 10-31-2012 04:09 PM
Art, I’ll have to try that tonight. I do remember the wood getting warm.
Also, since purpleheart is an oily wood (didn’t know that before), maybe a wipedown with denatured alcohol between passes (waiting for the wood to dry) would help. We’ll see later.
-- -- Don from PA
View rum's profile
rum
148 posts in 2489 days
#9 posted 10-31-2012 09:31 PM
was wondering about trying denatured alcohol as well – do let us know how or if that works :D
don1960
#10 posted 11-01-2012 03:22 AM
Well, I had some slight success with light passes and waiting if the wood got even the slightest bit warm until it cooled down. This with 120 grit.
Also tried wiping it down with denatured alcohol. Didn’t see any difference there at all.
By the time I had made 6 or 7 passes thru the sander, though , cleaning the belt with a crepe stick every second pass, it still bogged down and burned the wood. (only the purpleheart, the maple seemed to work fine)
Fortunately, by the time I had done all this, the board was as flat as it was gonna get. All that was left was some work with a ROS and a card scraper. It is as smooth as a glass plate now. That endgrain hardwood is some tuff stuff. Tomorrow i’ll round over the edges, and apply the finish. I think I’m done using purpleheart for endgrain boards though. Still have two more to make to take care of all the kids, but we’ll switch to maple and walnut I think. :-)
Bottom line on my new drum sander is I love it. Just have to watch what goes through it. Does amazingly on face grain boards. Looking forward to using it for a long time to come.
Thanks to everyone for the suggestions. I’ll post a pic when the board is finished.
-- -- Don from PA
PRGDesigns
#11 posted 11-12-2012 04:49 AM
Used the suggestion of letting the wood cool before running it through again with great success. Light passes, diagonal positioning, and medium feed rate combined with letting it cool resulted in a much better end result. Thanks for the heads up!
View polarbear3706's profile
polarbear3706
2 posts in 1776 days
#12 posted 04-09-2013 09:43 PM
I’m running into the same problem with my end grain on purpleheart. I’ve let it sit over night and tried sanding with various grits and even tried wood files. But the end grain continues to look darker and almost burned compared to the rest of the piece. Routers even at a medium speed seem to leave burn marks on the end. Any other techniques I could try or will I have to accept the different color at the end?
View SPalm's profile
SPalm
5315 posts in 3785 days
#13 posted 04-09-2013 10:15 PM
Oily woods and my drum sander are a problem. Padauk – yikes – some pieces even side grain just ruin belts. I have sent quite a few boards through and it is one of the most used tools in the shop, but some woods just hate it.
Some things that help: very light cuts, letting the wood cool between passes, and cleaning the drum with an eraser thingy. I have not tried solvents yet. I have no problem with Tightbond glue – maybe I’m lucky.
My V-Drum sander does a good job too as it runs so much cooler with no pressure rollers. But it has other problems with thickness control as it is more like a jointer than a thickness sander.
If only it was easy. Sticking to domestic hardwoods is the real way to solve this.
Steve
-- -- I'm no rocket surgeon
don1960
#14 posted 04-11-2013 02:37 AM
First, I have to apologize that I never posted the pic I promised when the board was done. Soo, late but here it is.
http://dtrust.smugmug.com/Woodworking/WoodWorking/11671471_zDNcZq#!i=2214220963&k=Nkv2nBM&lb=1&s=A
You can see the darker burn marks are still there in the purpleheart. I think Next one I’l try my new low angle block plane to shave a layer off the endgrain at the end. Maybe that’ll get rid of the burn.
-- -- Don from PA
View RogerInColorado's profile
RogerInColorado
321 posts in 1858 days
#15 posted 04-12-2013 12:13 AM
I read on some forum somewhere in the last couple of days about someone using abranet on his drum sander and getting astonishing results in both the burn department and the current draw department (he had an ammeter on his drum sander and the current draw with abranet was dramatically lower than with his “normal” sandpaper). He did complain about the cost, saying that the abranet was $33 but that he thought there was enough on the roll for three lengths of drum wrap. I thought that pretty reasonable since I pay about $45 for four strips for my Delta. I’ve never used abranet at all, so I don’t have any points of reference. I wish I could remember where I saw it so I could tell you where to look, but if I stumble across it again I’ll let you know.
