incra table saw fence
Forum topic by Joseph Jossem posted 203 days ago 826 views 1 time favorited 11 replies Add to Favorites Watch
View Joseph Jossem's profile
Joseph Jossem
164 posts in 437 days
203 days ago
Has anybody used the incra 52” system for cabinet saws
11 replies so far
View Howie's profile
Howie
2449 posts in 1092 days
#1 posted 203 days ago
I have the 52” on a general saw and love it. I also have an LS-25 on my router table. Can’t beat the Incra stuff for accuracy.
-- Don't rollerskate in a buffalo herd
View Greg The Cajun Box Sculptor's profile
3776 posts in 1477 days
#2 posted 203 days ago
I use the Incra LS systems on my table saw and my router table. Love them both and I would not change.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
View JesseTutt's profile
JesseTutt
707 posts in 279 days
#3 posted 203 days ago
I have the 32” on my saw. No complaints. I have an older Incra system on my router table and another on the drill press.
View live4ever's profile
live4ever
981 posts in 1179 days
#4 posted 203 days ago
Also have the 32” on my cabinet saw. Love it.
View TeamTurpin's profile
TeamTurpin
69 posts in 230 days
#5 posted 202 days ago
I’ll be buying the TS-LS system before the end of the year. I’ll be putting it on my Delta contractor’s saw and mounting a left-side router table. I’ve been wanting to upgrade my TS for years and this is a great way to do it.
Just need to save up some more buckaleros.
-- http://www.teamturpin.org/house/shop.htm
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1327 days
#6 posted 202 days ago
Another 32” user here. It’s my life. I would sleep with it if I could. :)
-- jay, www.allaboutastro.com
View Loren's profile
4883 posts in 1816 days
#7 posted 202 days ago
They are very accurate and repeatable, as advertised. They
take up a lot of space though. Electronic fence
accessories may be just as repeatable for t-square
fences.
Cosmicsniper
#8 posted 202 days ago
I’ve never found the extra space needed to the right side of the saw to be an issue. I place my DC right where the carriage extends to the right. So when I need to cut big panels, which isn’t often, I just nudge the DC over (it’s on wheels) to give clearance for the carriage. Unless you just have an exceptionally small shop, this really isn’t a “con.”
As far as using digital accessories with regular T-fences, maybe. But with the Incra, you lock down immediately on 1/32” increments because of the lead-screw design. That means for wicked fast cuts, something you couldn’t really get with a digital T-fence.
Of course, the other half of the package is when you put a router in your TS wing. The router package and wonder fence provide great amounts of versatility and functionality. But even if I didn’t have that, the TS fence MORE than pays for itself in time saved.
Joseph Jossem
#9 posted 202 days ago
thanks for the responces I am going to order one.Gotta figure out if it will fit on a 12” oliver saw I saw incra has xl versions that should work I think.Loren what are the electonic accessories?
#10 posted 202 days ago
Oh, like the Wixey table saw digital readout. It’s a downmarket
version of the system sold for pro shops by Accurate Technologies.
It may be a trick to find crosscut scale tape that matches the
Wixey, but other than that it’s said to be near perfect in
terms of accuracy. I read somewhere that Johnson brand
tape measures and stick-on tapes match the Wixey pretty
well.
... for that matter it may be a trial to find stick on tape that
matches the INCRA perfectly… or at least to within 1/100th
of an inch.
JesseTutt
#11 posted 202 days ago
I came up with a solution to the Incra fence sticking so far out to the right on wide cuts. My table saw right side is against the shop wall. I cut a rectangular hole in the wall and added a hinged drop down door. Now when I need a wide cut I open the door and the fence slides right out into the covered car port. Does not seem like I lose much heat out the 24” x 6” opening, of course in the spring and fall it is open to increase air flow.
