Inlay jewelry in wood.
Forum topic by Dave posted 205 days ago 776 views 1 time favorited 32 replies Add to Favorites Watch
View Dave's profile (online now)
Dave
9200 posts in 1011 days
205 days ago
Topic tags/keywords: question
I need to set some silver jewelry in maple. I would like to epoxy it in. I know you can get it in a clear quart size. I need just enough for this one project. Does any one know of a clear material I can do this with and only buy a few ounces?
32 replies so far
View Brit's profile
Brit
4201 posts in 1014 days
#1 posted 205 days ago
I’ve got no idea personally Dave, but you should ask RGTools (Ryan). He is a jeweller and will probably be able to suggest something suitable.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
Dave
#2 posted 205 days ago
Thanks Andy. This is a good one. I will take your advice.
View Ted's profile
Ted
1400 posts in 382 days
#3 posted 205 days ago
Every hardware store, paint store and automotive store sells the small tubes of 2-part epoxy. Some sets in 5 minutes and some sets in 5 hours. It’s not transparent when you mix the parts, it turns cloudy or cream color, but then it turns clear as it sets. I’m not sure how it effects the wood.. staining it or bleeding into the grain. Of course, try a sample before committing it to your project.
-- I'll grow up when ketchup bottle farts stop being funny.
View Joe Lyddon's profile
Joe Lyddon
6396 posts in 2223 days
#4 posted 205 days ago
You can always protect the edges where the silver will be by carefully brushing on some blonde shellac around the edges… sand away the shellac when done…
Dave
#5 posted 205 days ago
Ted that is what I was doing was looking at the tubes and they all seemed not to be clear. I might have to try a test run with some.
Joe shellac never came to my mind. Thanks
View gfadvm's profile
gfadvm
6650 posts in 861 days
#6 posted 205 days ago
Dave, BentlyJ highly recommended “clear casting epoxy” from Michaels when I asked him about a similar application. I have also seen smaller sizes of West System 3 epoxy at Woodcraft.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6253 posts in 1606 days
#7 posted 205 days ago
Dave, HF sells 2 small tube epoxy for 99c. I have used it before and it works very well, just don’t get it on your thumb though, I’ve had my thumb stuck somewhere for the last two years that does not show daylight.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
Dave
#8 posted 205 days ago
Andy thank you. A jewelry store.
thank you to Roger. You always leave em smiling.
Roger Clark aka Rex
#9 posted 205 days ago
That’s my job Dave.
The cheap HF stuff does work OK, maybe for a test, then you can decide to use it on a real project or go for the same stuff with a fancier name and more fashion conscious tube.
gfadvm
#10 posted 205 days ago
Dave, Michaels is a craft type store (like hobby lobby)
Joe Lyddon
#11 posted 205 days ago
Dave, here I used shellac to protect the edges from the colored epoxy... I didn’t want any bleed thru around the edges.
I painted the top untaped surface with Blonde shellac… being careful not to get it over the edge.
Ended up with a nice crisp edge.
Dave
#12 posted 205 days ago
Got it Rex,
I have a hobby lobby, thanks Andy
Great link Joe.
Every little bit helps guys.
View Roger's profile
Roger
9192 posts in 975 days
#13 posted 205 days ago
Very interesting question. Sorry, I don’t have any input, but, I can’t wait to see what you’re comin up with. Although, what about after inlaying the jewelry, mirror coat over the top??? Don’t know if that’s any answer or not. I’ve never used it before. yet.
View maw4's profile
maw4
2 posts in 210 days
#14 posted 205 days ago
I would suggest your local craft store and check out the jewelry section. Using epoxy for jewelry is popular and they want it to be clear. You could check youtube for videos, they usually tell you what brand they are using. Because it’s for jewlery, it comes in smaller amounts.
Dave
#15 posted 205 days ago
Roger what is mirror coat?
Thanks maw4 for the info.
showing 1 through 15 of 32 replies
