| Forum topic by Rookie702 | posted 206 days ago | 963 views | 0 times favorited | 14 replies | ![]() |
206 days ago |
The long and short of it is this, I don’t have a nice workbench with all those little bench dogs and a vice or two at the end off the bench to use to hold down stock while i am either sanding, planing, gluing or what have you, so i was curious what are some methods of holding down stock to a workbench. I do have some counter space, but more times than not, i throw a piece of 3/4” plywood on top of a 7 ft pool table that i have in my garage and use that for a table top. It seems like every time i use a clamps, they get in the way, and i really don’t want to screw a new piece of wood down for every different piece of stock i might work on. I have made a couple of cutting boards of different sizes the last week, and for the life of me i have more trouble holding in place than anything else. Any ideas would be greatly appreciated. Thanks guys. |
14 replies so far
#1 posted 206 days ago |
Bench cookies work really well if your piece is heavy enough to make the friction prevent sliding. I hear bench hooks are good for planing stops, too, though I’ve never tried them. |
#2 posted 206 days ago |
I use a piece of carpet pad, or those perforated black rubber tool drawer liners to hold some of the smaller pieces still while sanding and hand planning. If I need more holding power for like routing I’ll add a bench hold down to that. I have one hole in the bench for the hold down to go through. -- I don't make mistakes, I have great learning lessons, Greg |
#3 posted 206 days ago |
bench hook is a good idea take two boards 1×8 and a 2×8 the thin one about 10 inch longer than the other Dennis |
#4 posted 206 days ago |
I do all of the above, and another trick. If size allows, I’ll clamp a board to the back of my bench behind my vice, so my piece is hanging off the edge just a little. I usually use a 1/2” thick piece so when working with 3/4, I have some room. Then I put a piece of wood in my vice sticking up just below the piece I am working on. I crank the vice to hold the piece snug |
#5 posted 206 days ago |
built a shooting board already, love that thing. guess im not sure what a bench hook is, what is the best type of top mounted hold down. |
#6 posted 206 days ago |
Here’s a bench hook http://lumberjocks.com/projects/3000 I’ve never had a bench with bench dogs and have used many of the above techniques -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#7 posted 206 days ago |
If you have saw horses and two short parallel clamps (my preference), then you can use these to do edge work on your boards. Put the horse close together and hook up the clamps, alternating them front and back of the horses. Put the board upright between the horses using them as jaws. The board holds strong. It’s like a poor man’s Workmate, only more substantial when using bigger horses. -- jay, www.allaboutastro.com |
#8 posted 206 days ago |
I use a pop up planing stop, Grammercy holdfasts, bench hooks, and if I have to… my vises. It’s amazing how useful good holdfasts can be, even with power tools. -- It's all good, if it's wood... |
#9 posted 206 days ago |
Rookie, there are a whole bunch of improvised methods for holding stock which are really only limited by your imagination I guess. I would like to suggest that a good workbench is more conducive to proper stock holding chores and because of that, is safer for you and your tools. It sounds like you are invested in the hobby enough to warrant a bench and while there are some benches out there that cost a good sum of money, you do not have to buy a new expensive one. I have seen decent workbenches for sale on Craigslist, so if you don’t want to make one, you have other options. If you are interested in making your own (highly recommended, I built my first one), you would be surprised to find it doesn’t take much time and doesn’t cost very much money at all. FineWoodworking has a video series on a simple bench which was very easy to make. http://www.startwoodworking.com/getting-started/season-two This bench includes a vice and dog holes for holdfasts which coupled together will perform most stock holding chores. One nice thing about building your own is you can modify the plans to fit your own needs. Maybe add a second vise or build provisions for a tail vise, whatever. And there really is no better accomplishment than building your own tools and putting them to use (a workbench IS a tool). That’s my two cents, Good Luck! -- Mike |
#10 posted 205 days ago |
Members of LJ have many ingenious ways for dealing with your problem. And many turn out great pieces of work using only the most basic of tools. But paratrooper is right. A good bench is actually just a clamping tool. Your work will become so much easier when you can work on the full face of a piece and reposition it in seconds, and have it held rock steady. Heck, you might even be able to use handplanes. But if a bench isn’t in your future, you can sure do a lot of things without one. -- Trees, a wonderful gift --Joe-- |
#11 posted 205 days ago |
When I use the ROS I use a piece of short nap carpet. It holds the work down and you don’t even need to hold on to it. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#12 posted 205 days ago |
Before I could afford an MFT3, I purchased a Festool top and built If you run cleats on the wall, you can make it sturdy enough |
#13 posted 205 days ago |
Bernouli clamps are another way to go. -- Bondo Gaposis |
#14 posted 205 days ago |
Cam clamps are easy and work well. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15793 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
