Cutting boards
Forum topic by nate22 posted 10-29-2012 02:31 AM 940 views 0 times favorited 5 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 2780 days
10-29-2012 02:31 AM
I am wondering how you make lazy Susan’s. Any answers would help.
-- Gracie's wooden signs. Middlebury, In.
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#1 posted 10-29-2012 02:47 AM
I just did my first “no hardware” lazy susan today. It looks like it is going to work. The top is a 15” circle, bottom is a 12” circlewith a 1” hole through the center, I then glued a 9” circle (1/4” ply) with a hole in the center to the bottom as a spacer between the top and bottom. The pivot is a 1” dowel glued in the bottom. The top has a 1” hole 3/4 of its thickness and just sits on top of the base. A little wax and it spins freely with no appreciable wobble. It would be easier to buy the hardware from Rockler and just put it together. But where is the fun in that?
View Jim Jakosh's profile
Jim Jakosh
20071 posts in 3010 days
#2 posted 10-29-2012 12:51 PM
I buy a ring of ball bearings and screw them under the top plate. They are pretty cheap now- only a few bucks.
If you made one without it, it seems it will have to be some real slippery material in between with a pivot post in the center with a screw and washer on the bottom so the two plates can’t separate…............Jim
gfadvm
#3 posted 10-30-2012 10:47 PM
I posted my no hardware version today (in projects). I’ll try to do a link thingy but I usually fail!..
View SASmith               's profile
SASmith
1850 posts in 2891 days
#4 posted 10-30-2012 11:41 PM
Here is gfadvm’s version.
-- Scott Smith, Southern Illinois
gfadvm
#5 posted 10-31-2012 12:40 AM
Thanks Scott. I don’t know why I can’t master that simple skill. Don’t bother trying to teach me. I have been detailed on every technique for posting links imaginable but I’m too stupid to get it.
