| Forum topic by Manitario | posted 202 days ago | 1574 views | 0 times favorited | 18 replies | ![]() |
202 days ago |
I’m building a dining room table using several 2.5” thick slabs of elm. On one of the ends there are a couple of long cracks through the slabs. I’ve seen many tables like this with “butterflies” over the cracks; my questions for those of you that have done this: -- Rob, Sault Ste. Marie, Ontario |
18 replies so far
#1 posted 202 days ago |
The butterflys should be about half the slab thickness. The cracks will probably progress. The butterflys will enhance the appearance. I was told by a man with lots of experience that a blemish can be enhanced by calling attention to it. -- Jerry |
#2 posted 202 days ago |
I don’t usually make my butterflys that think. I think 1/2” to 5/8” is enough. If the wood isn’t completely dry the crack may continue. If its done moving it may not. Sometime you can glue the crack and clamp it shut before you add the butterfly, depending how far and how bad its cracked. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#3 posted 202 days ago |
I have filled cracks with epoxy and then inlayed 1/4-3/8” thick butterflies. So far, so good. Elm can be more difficult than the walnut I have done so your milage may vary. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#4 posted 202 days ago |
I like to go 2/3 the thickness. I’ve used this method for many years and have never had issues with the cracks opening further. |
#5 posted 202 days ago |
Just a thought, but if you want to stop those splits getting bigger, could you drive a couple of long screws discretely at the end of the split to pin it together. You can still add glue and as many butterflies as you like. -- Do or do not, there is no try |
#6 posted 202 days ago |
if you want the table build without the cracks good luck |
#7 posted 201 days ago |
Thanks for the replies guys. I like the cracks in the slabs; the table will have live edges so the cracks add character; I just don’t want them to eventually destroy the table! -- Rob, Sault Ste. Marie, Ontario |
#8 posted 197 days ago |
My understanding is that butterflies are used to strengthen a cracked panel. For example, if a tabletop has cracked, you need to strengthen the top so that if someone sits on it, for example, the panel doesn’t flex to the extant that the crack extends further across the panel. In short, the butterfly prevents a downward force (90 degrees to the panel) from flexing a panel weakened by having a crack through it. I suspect your cracks are the result of tensions from within the slab and, unless the wood is done moving (tensions are stabilized), I doubt butterflies will help. However, to prevent the cracks from extending as a result of heavy downward pressure, butterflies can be your solution. But make sure they are thick enough to add strength and not just decoration. -- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse |
#9 posted 197 days ago |
done numerous of these, what I do is to use some of the pour on stuff either the epoxy or the polyester stuff |
#10 posted 197 days ago |
Great advice on the slower curing epoxy to really fill the internal cracks and really stabilize and strengthen things, Charles. Also good advice on the quick coat of shellac to help the tape fully seal! -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
#11 posted 197 days ago |
Thanks for the advice guys! I picked up some Envirolite tonight Charles; I’ll give it a try, it certainly is a lot easier to use than chiseling out butterflies on areas people will never see. -- Rob, Sault Ste. Marie, Ontario |
#12 posted 197 days ago |
here is a little more on using the epoxy/enviorlite, it really does well on slabs, that could be prone to having issues, not to say this is the cheapest way or the only way, but it has never failed me, http://intheworkshop.wordpress.com/2010/10/19/clario-slab-finishing-and-stuff/ |
#13 posted 149 days ago |
An update; I used the Envirolite; it was easy to use and has a long open time which was helpful because many of the cracks were quite deep and took a lot of epoxy to fill. Its other advantage is that it is relatively thin, so again, easy to pour into cracks. It also drys clear, compared to some 5 min epoxies that have a yellowish tinge. I also ended up using butterflies that were 2/3 the thickness of the top; not easy to do considering the top is 2 1/4” thick, but I hope this will prevent any further cracking in the long run. -- Rob, Sault Ste. Marie, Ontario |
#14 posted 149 days ago |
will we see pic’s ? A link to a project ? -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#15 posted 149 days ago |
Hey Don, I’m just putting the final coats of finish on it…I’m hoping after Christmas I’ll be able to recruit a couple of guys to help me wrestle it from the shop into the house (the top weighs in excess of 150lbs) and then post some pics. -- Rob, Sault Ste. Marie, Ontario |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
