glue rubber pad back on plastic push block / handle?
Forum topic by JesseTutt posted 10-27-2012 03:55 PM 1311 views 0 times favorited 1 reply Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 2014 days
10-27-2012 03:55 PM
Topic tags/keywords: question push block glue rubber
About a year ago, a well known nationwide woodworking chain, offered a 4 piece safety set for a good price. Yesterday, I needed a push block and opened one of the sets. I double-sided taped it to the piece and it worked well. But, when I attempted to pull off the block the glue that holds the rubber to the plastic was weaker than the double-sided tape.
So, what is the best glue to use to put the rubber pad back on the plastic handle? I have Tight Bound, TB 2, TB3, Epoxy and 3M spray mount on the shelf.
On the other hand, I sometimes screw a push block to a bigger piece of wood (to keep the wood square and prevent tear-out). Would I need the rubber pad?
1 reply so far
9937 posts in 3551 days
#1 posted 10-27-2012 07:20 PM
Scuff up the surfaces with 80 grit paper and glue under pressure
with white or yellow glue. Contact cement is probably a better
adhesive for rubber-to-plastic, but if you don’t have it on hand…
