Wet Sanding vs Dry Sanding
Forum topic by gfadvm posted 10-27-2012 01:32 AM 4300 views 0 times favorited 10 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2924 days
10-27-2012 01:32 AM
Topic tags/keywords: wet sanding lubricants
When sanding finishes to 600 and higher grits, what is the advantage of wet sanding? Question #2: What lubricant is best for wet sanding shellac? Thanks for considering these.
10 replies so far
View NiteWalker's profile
NiteWalker
2738 posts in 2811 days
#1 posted 10-27-2012 01:38 AM
1. The main advantage is lack of sanding dust to clog up the paper or the air. It also goes a lot easier.
2. I’m no expert on the subject, but I’d not wet sand shellac. Otherwise I use distilled water with a bit of dawn as my lube. I learned the trick from Charles Neil.
View DocSavage45's profile
DocSavage45
8731 posts in 3077 days
#2 posted 10-27-2012 01:38 AM
Only know about wet sanding in car painting. Creates a slurry using the paint that comes off as additional sanding material. But thats from a novice painter. Be interested in the responses.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View vonhagen's profile
vonhagen
541 posts in 2599 days
#3 posted 10-27-2012 01:39 AM
no heat will be generated and and you will get a full fill finish or piano finish. water is what i use
-- no matter what size job big or small do a job right or don't do it at all.
View hhhopks's profile
hhhopks
654 posts in 2612 days
#4 posted 10-27-2012 01:57 AM
Your sandpaper will last much longer (less clog).
I have used water and Mineral Spirite.
I like water because it is cheap and easy to work with.
I believe the lubricant needs to be compatible to the finish (not interfere).
-- I'll be a woodworker when I grow up. HHHOPKS
View JoeyG's profile
JoeyG
1275 posts in 2860 days
#5 posted 10-27-2012 02:09 AM
I see something shiny coming from this post. Wish I had more to add but I don’t really use shellac.
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
View nomercadies's profile
nomercadies
590 posts in 2573 days
#6 posted 10-27-2012 02:17 AM
I’ve sanded drywall with a wet (water) washcloth or towel and had great success, but wood? Cool!
-- Chance Four "Not Just a Second Chance"
gfadvm
#7 posted 10-27-2012 02:42 AM
Blaine, Is water OK to use on shellac? Add a little detergent?
View BTimmons's profile
BTimmons
2303 posts in 2719 days
#8 posted 10-27-2012 03:29 AM
As far as I know, water should be ok on shellac…right? Please, anyone correct me if I’m wrong. Since shellac is resin dissolved in alcohol, it’s alcohol that you have to keep away. Because then you won’t be wet sanding, you’ll be stripping all the finish off altogether.
-- Brian Timmons - http://www.BigTWoodworks.com
View Jorge G.'s profile
Jorge G.
1537 posts in 2709 days
#9 posted 10-27-2012 03:40 AM
If you wet sand shellac you might get blushing, the proverbial white ring from a wet glass. Any light oil, like mineral oil, furniture oil etc would be best.
-- To surrender a dream leaves life as it is — and not as it could be.
vonhagen
#10 posted 10-27-2012 10:51 AM
andy i believe you are trying to get a full fill finish here right? you need to let the shellac fully dry to wet sand and only after about the third coat should you start wet sanding. and use only water.
