Question about burnishing
Forum topic by Blackbear posted 10-26-2012 05:13 PM 2648 views 0 times favorited 5 replies Add to Favorites Watch
View Blackbear's profile
Blackbear
137 posts in 2340 days
10-26-2012 05:13 PM
Topic tags/keywords: question oak finishing burnish
I recently completed some cribbage boards as retirement gifts for 5 coworkers. The finish I used was Danish Oil, which I like a lot. This is the first time I used Danish Oil on Red Oak. Two weeks after the last coat was applied, the oil is still seeping slightly out of some of the open grain. One of the supervisors at work had the boards stacked in his desk drawer. I placed paper towels between each board, but he put a plastic bag on the top board. We went to get one of them to give out today, and there was a few half dollar sized lacquer pools that had dried on the surface. We both feverishly scrubbed the lacquer away with a paper towel. The result was a really nice burnished surface that was smoother and slightly more shiny than before.
Now I thought I had been burnishing a bit with some 000 steel wool after the last coat cured for a few days. It seems like the paper towel did a much better job however, which raises the following three questions to the more experienced woodworkers around here:
1. What kind of finishes do you typically burnish?
2. What cloth/tool do you use to burnish?
3. Do you always burnish, or only specific types of projects?
Thanks in advance.
5 replies so far
View Bill White's profile
Bill White
5054 posts in 4081 days
#1 posted 10-26-2012 05:37 PM
Burnished wooden objects with a brown (kraft) paper bag material will yield a very nice finish. The brown paper is just abrasive enough to polish. I use it on lathe projects with wax finishes as well as wiping varnish.
Bill
-- bill@magraphics.us
View Toolz's profile
Toolz
1004 posts in 3863 days
#2 posted 10-26-2012 07:55 PM
Depending on size, you can also use a very old trick: rubbing with a piece of smooth bone or even the smooth side of an old plastic toothbrush. The pressure seems to really help close open pores in the wood. I remember “boning”(as it is called) the stock of an old Springfield ‘o3 until it was glassy smooth.
-- Larry "Work like a Captain but Play like a Pirate!"
View Earlextech's profile
Earlextech
1162 posts in 2811 days
#3 posted 10-26-2012 08:05 PM
Every once in a while when you are asked, “Paper or plastic?” get the paper. Burnishing doesn’t necesscerily mean polishing, it depends how far you take it. I always burnish my kitchen doors and drawer fronts because it make a smoother surface that customers love.
View paratrooper34's profile
paratrooper34
915 posts in 3073 days
#4 posted 10-26-2012 08:10 PM
Burnishing is also effective when you use shavings from the wood you are working with. Save your shavings from planing, gather them up and start rubbing away with them. Obviously you need your plane set to take whispy shavings. It works great!
Good Luck!
-- Mike
Blackbear
#5 posted 10-27-2012 01:08 AM
Thanks all! Do you usually burnish most types of finish you use?
