| Forum topic by ADHDan | posted 204 days ago | 265 views | 0 times favorited | 2 replies | ![]() |
204 days ago |
I need to put a 1/8” rabbet on the inside edge of some picture frames I’m making. The frames are already assembled, so I need to use a rabbet bit with bearing. I have a rabbet bit from the MLCS 8377 bit set (http://www.amazon.com/MLCS-8377-15-Piece-Router-Carbide-Tipped/dp/B000FJRN8S/ref=sr_1_2?ie=UTF8&qid=1351256878&sr=8-2&keywords=router+bit+set). With the included bearing, I think this bit cuts a 3/8” rabbet – which is way too deep and likely will nick my pocket screws. Will either of these bearing sets work with my MLCS rabbet bit, and give me a 1/8” rabbet profile? http://www.amazon.com/Amana-6000-bearing-kit/dp/B000P4OKQG/ref=sr_1_2?ie=UTF8&qid=1351256967&sr=8-2&keywords=router+bearings Or would anyone recommend a different bearing set? Thanks! -- Dan in Minneapolis, woodworking since 11/11. |
