Is this purpleheart?
Forum topic by ErikF posted 209 days ago 539 views 0 times favorited 14 replies Add to Favorites Watch
View ErikF's profile
ErikF
132 posts in 413 days
209 days ago
I was rummaging through my lumber a few days ago and came across this board at the very bottom of a stack of santos mahogany. It is 9/4×8” x 9’ and I was hoping to save myself some gluing by cutting a set of legs out of it…cut the appropriate length and it smelled a lot different then expected and it had a purple tint to it. Ran it through the planer today so I could ask you fine folks what it is.
I have never used purpleheart and that is my first guess. It also has a slight mustard smell to it…
-- Power to the people.
14 replies so far
View shampeon's profile
shampeon
517 posts in 353 days
#1 posted 209 days ago
Put it in some direct sunlight or fluorescent light for a few days. If it’s purpleheart, it will start turning bright purple before eventually darkening up.
View Dusty56's profile
Dusty56
10513 posts in 1857 days
#2 posted 209 days ago
http://www.hobbithouseinc.com/personal/woodpics/purpleheart.htm
Doesn’t appear to be PH to me ,at least not what I have seen and worked with to date , but check out the HobbitHouse link : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View DrDirt's profile
DrDirt
1783 posts in 1912 days
#3 posted 209 days ago
Follow shampeon’s advice.
Put it out for a couple hours in direct sunlight and it will be unmistakably purple.
Freshly milled it is brown – then become purple with oxidation.
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View NiteWalker's profile
NiteWalker
1473 posts in 746 days
#4 posted 209 days ago
Yep, that’s purpleheart.
View WoodYard's profile
WoodYard
28 posts in 1181 days
#5 posted 209 days ago
Shampeon is dead on. Exposed to light it will purple up in 3-4 days with indirect sun. Walnut?
-- Rick Wood TheWoodYard.com
ErikF
#6 posted 209 days ago
Thanks for the responses. I’ll put it out on my porch for a few days and see what happens. I am pretty positive that it isn’t walnut…tropical density and a different smell.
View PRGDesigns's profile
PRGDesigns
177 posts in 483 days
#7 posted 208 days ago
Could it be Bubinga? How did the wood do in the planer? Easy or with some difficulty? If it planed easily, it just might be Bubinga. If it sounded like 2 cats killing each other, I would lean towards PH. If you have something to compare it to for weight, PH will weigh appreciably more than almost any other wood of a similar size you have in your shop. In my opinion, if it is PH, it should still be much more purple than the picture I am seeing on my laptop, if it hasn’t been exposed to sunlight for an extended period of time.
-- They call me Mr. Silly
NiteWalker
#8 posted 208 days ago
He said he found it at the bottom of the stack.
I had some purpleheart not too long ago look identical. In fact I still have it, it’s just that beautiful bright purple now. And yep, pick it up, ph is very heavy.
View Howie's profile
Howie
2449 posts in 1092 days
#9 posted 208 days ago
This item should be sent to me immediately for proper disposal!
Looks like PH to me.
-- Don't rollerskate in a buffalo herd
View AUBrian's profile
AUBrian
70 posts in 841 days
#10 posted 208 days ago
Looks like it could be Lyptus as well….I have some that’s the exact same color.
ErikF
#11 posted 208 days ago
I’ll be putting it on the porch today…lets see what that California sunshine does for it’s color.
Howie,
I am not a very big fan of purpleheart and would consider giving it to you if it wasn’t so heavy…shipping would be a nightmare. Also, I am a bit of a wood hoarder so even though I would know deep down I should clear out the valuable space, I would probably break down and have to keep it in the end. :)
Howie
#12 posted 208 days ago
Erik, key word here is ..heavy. Another characteristic of PH. Seriously, that is one expensive board
View lumberjoe's profile
lumberjoe
2398 posts in 418 days
#13 posted 208 days ago
This is a purple heart pen I turned from cutting board scraps. It was a DEEP purple before I turned it. Now that it has finish on it and hasn’t seen any light (I keep my pens in a box) it has not gone back to the deep purple color.
-- http://www.etsy.com/shop/KandJWoodCrafts
View jusfine's profile
jusfine
2152 posts in 1095 days
#14 posted 208 days ago
Looks like purpleheart to me. I have lots of it, if anyone is interested…
Mostly 5/4 rough stock, 6-8’ long and most boards are about 8” wide.
Shipping would not likely be advantageous unless you want pen blanks or a couple smaller pieces.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
