| Forum topic by jacob34 | posted 211 days ago | 336 views | 0 times favorited | 8 replies | ![]() |
211 days ago |
I have a minwax poly stain mix and used it well over a year ago then closed it and put in away. I went to open it up and use it a week ago and it was solid. I need to know if I can fix that or if it is ruined. I have searched online but not finding anything, either most know how to keep it from happening or it is ruined I don’t know. My daughter love her to death but she pulled the label off a while back so if there is info on the label please let me know. It was not in a hot place and was closed tight so any help is appreciated. -- two men walk into a bar the third one ducks, which are you?? |
8 replies so far
#1 posted 211 days ago |
There is no fixing it. I’d also suggest keeping it away from your daughter. I’ve had poly last a long time, much longer than a year, so id say it wasn’t air tight for some reason. It will also get hard quicker if there is only a little left in the can. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#2 posted 211 days ago |
Toss it. -- Sam Hamory - The project is never finished until its "finished"! |
#3 posted 211 days ago |
I second what Don said. If it’s solid, it’s basically cured, and you can’t reverse that. Maybe a small piece of saran/cling wrap under the lid when you put it away for long term storage would work better. -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#4 posted 211 days ago |
Junk. I started exhaling into the can just as I replaced the lid on all finishes. Remember that most of our air is a high nitrogen mix. Inert gas (nitrogen) helps prevent curing. Not a total prob solver, but sure helps. -- bill@magraphics.us |
#5 posted 211 days ago |
A good tip I learned recently – if you are a welder, hit the can with some argon before you seal it up. If you are not a welder or do not have argon, fill the can with glass marbles to remove as much “space” as you can. |
#6 posted 211 days ago |
Aren’t glass marbles worth more than the poly these days :-) -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#7 posted 211 days ago |
They cost about as much as 1 quart of Arm-R-Seal, however they cost a lot less than the four 3/4 full cans of solid material I used to call Arm-r-Seal :) If the volume of projects I finished was great enough where I could go through finish quickly, it wouldn’t be an issue. A quart of finish will last me a LONG time. |
#8 posted 211 days ago |
Glass marbles can also be recycled. They last until….well you lose your marbles. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
