Grizzly D/C 3hp vs 2hp
Forum topic by Bumblebeetuna96 posted 10-25-2012 03:54 AM 1179 views 0 times favorited 10 replies Add to Favorites Watch
View Bumblebeetuna96's profile
Bumblebeetuna96
3 posts in 1913 days
10-25-2012 03:54 AM
Topic tags/keywords: grizzly dust collector
Hey everyone I’ve been lurking this forum for a while, first time posting however.
I’m looking to put a dust collection system in my two car garage. Looking at grizzly a site they offer a 2hp unit with a 1 micron “canister ” style filter for 445. And a 3 HP unit with two filters at 2.5 microns for 425
Question is whether the filter is worth less HP or vise versa
10 replies so far
View JesseTutt's profile
JesseTutt
853 posts in 1984 days
#1 posted 10-25-2012 04:34 AM
Harbor Freight 2hp collector currently on sale with coupon from Wood magazine for $150 + Wynn Nano filter (99.9x of .5 micron particle) $170 + shipping. Better capabilities for less money.
View knotscott's profile
knotscott
7820 posts in 3249 days
#2 posted 10-25-2012 10:28 AM
The jump to the cannister filter is a step in the right direction….not just for the improved filtration, but for the improved airflow….a cannister will have 5x to 6x the airflow of a standard bag. The 2hp Griz has 12-3/4” impeller, and a steel chute that really moves a lot of air. (FWIW, the HF DC has an impeller in the range of 10-3/4”, and isn’t a true 2hp motor….it’s a good value if you’d rather save some money, but doesn’t perform at the level of the 2hp Griz). I don’t think you’d need the capacity of the 3hp DC….it offers a lot of potential, but you’d need to add ~ $250 – $300 worth of cannisters to get the filtration level in the range of the 2hp unit.
Note the difference in impeller size:
View toolie's profile
toolie
2101 posts in 2502 days
#3 posted 10-25-2012 02:44 PM
+1 on kotscotts’s comments. good advice that will get you good dust collection performance. when you get it, add a baffle to the drum ring and keep as much dust as possible out of the filter, like this:
http://lumberjocks.com/topics/40189
View Brickman's profile
Brickman
51 posts in 2244 days
#4 posted 10-25-2012 07:45 PM
The 3 HP model with canister filters has a sound rating of 87 db. The 2 HP model has a sound rating of 74 db. I would assume the bagged model of the 3 HP is very close in sound rating to the 3 HP canister model. Since the decibel scale is logarithmic that is a huge difference in the amount of noise they produce.
I have the 2 HP HF and looking back I probably should of just went with the 2 HP Grizzly and been done with it instead of trying to mod it to get it to behave like a more capable DC.
-- Mark - Pueblo, Colorado
Bumblebeetuna96
#5 posted 10-25-2012 09:05 PM
Thanks for the advice. Also, would the 2HP be strong enough for permanent PVC pipes and gates?
View Grandpa's profile
Grandpa
3259 posts in 2549 days
#6 posted 10-25-2012 09:46 PM
about 2 years ago I was standing in the Grizzly store in Springfield, Mo. looking at those 2 dust collectors sitting onm the showroom floor. I was compairing the differences when a man walked by ( a customer) and said in passing. Go ahead and get the larger one then you won’t have to take the small out and buy the larger on later like I did. So I had that tucked in th eback of my mind when I went shopping. I ended up ordering a 5 hp Clear Vue. I have a 30×40 shop. I added a 2 ft extension to the end so when I installed the unit I actually housed it in the addition and I piped through the wall.
toolie
#7 posted 10-25-2012 10:50 PM
grandpa implies a good point relative to your question about the 2 hp being able to support fixed piping. it would depend on the size of the shop. my 12×20 shop does quite well with one run of fixed pipe and a 1.5hp 50-850. in a shop 5 times the size of mine, i wonder if a 2 hp would be adequate.
Bumblebeetuna96
#8 posted 03-24-2013 10:47 AM
Im finally ready to.pull the trigger on this. Im going with the cannister and im going to try and run 6” pipes. Does anyone know if there are any grizzly coupons out there at this time
Shawn Masterson
1324 posts in 1822 days
#9 posted 03-24-2013 02:02 PM
spring sale 4/1 you might want to wait. either way go bigger now and save more down the road.
View gtbuzz's profile
gtbuzz
427 posts in 2315 days
#10 posted 03-25-2013 03:45 AM
@knotscott…
You said I don’t think you’d need the capacity of the 3hp DC….it offers a lot of potential, but you’d need to add ~ $250 – $300 worth of cannisters to get the filtration level in the range of the 2hp unit.
Could you expand on that? Not sure I follow.
