What do you use? Wood runners, or aluminum runners?
Forum topic by AJswoodshop posted 10-25-2012 01:24 AM 4141 views 1 time favorited 20 replies Add to Favorites Watch
View AJswoodshop's profile
1057 posts in 2206 days
10-25-2012 01:24 AM
Topic tags/keywords: tablesaw
On all of my sleds and TS jigs I cut my runners out of hardwood. My TS sled slides nicely but I wonder how aluminum runners slide? What do you use? Aluminum runners, or wood runners?
20 replies so far
View thebigvise's profile
191 posts in 2830 days
#1 posted 10-25-2012 01:56 AM
I’m sure that there are a variety of opinions on this, but I used aluminum bar stock. I then tapped threaded holes in the sides for nylon set screws for micro-adjust capability. I have been very happy.
-- Paul, Clinton, NC
View nwbusa's profile
1021 posts in 2215 days
#2 posted 10-25-2012 01:58 AM
Neither :) I use UHMW:,43576,32045
These Incra steel bars are really nice, too:,43455&p=65247
-- John, BC, Canada
View NiteWalker's profile
2736 posts in 2506 days
#3 posted 10-25-2012 01:59 AM
I like metal runners. I plan on getting a couple of incra's new glide lock runners. They’re the same they use on their miter gauges and are amazingly smooth sliding and adjust for the fit.
Wood runners will work fine though, so long as you choose a stable hard wood.
#4 posted 10-25-2012 02:57 AM
Thanks for the comments guys. I think I might try aluminum runners soon.
View Joe Lyddon's profile
Joe Lyddon
10047 posts in 3981 days
#5 posted 10-25-2012 03:01 AM
I use wood runners…
These are pretty good Metal runners... (if you want to pay the price)
I also use UHMW strips, one on each side of the bottom… Slides really SMOOTH…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View Don Broussard's profile
Don Broussard
3500 posts in 2181 days
#6 posted 10-25-2012 03:03 AM
Hardwood runners on my crosscut sled.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View jumbojack's profile
1673 posts in 2553 days
#7 posted 10-25-2012 03:14 AM
Mine are all wood. some of my one time jigs, I use mdf. For things I will use more than once I use maple. On jigs like the miter slot cutter, I tear one up a year, I save them for the next one. I really should make a nice miter slot cutting jig. I paste em together and just saw through them, where ever the slot needs to be cut.
View pintodeluxe's profile
5587 posts in 2742 days
#8 posted 10-25-2012 03:18 AM
For my crosscut sled I use metal runners with the small ball bearings on the side to eliminate any slop.
Most of my other jigs use the fence, rather than the miter slots. My tapering jig is held against the fence with a featherboard. My tenoning jig rides over the fence.
Good luck AJ
View Woodknack's profile
11286 posts in 2309 days
#9 posted 10-25-2012 06:32 AM
Plywood, hardboard or plastic. No idea what the plastic is but it’s slick, I got a bunch of it for free.
-- Rick M,
View BinghamtonEd's profile
2286 posts in 2299 days
#10 posted 10-25-2012 12:27 PM
I use scrap wood because I’m cheap like that. Never had any issues. Metal or plastic would be nice, but so long as I have scrap, I have runners.
View Jim Jakosh's profile
Jim Jakosh
20162 posts in 3035 days
#11 posted 10-25-2012 12:47 PM
Hi AJ. My table saw is different from most, it is a Ryobi and has no slot in the top for the typical runner. My sled fits over the center housing and I made slippery plastic glides for the bottom and sides so it slides effortlessly back and forth. I have a lot of this stuff, so if it would wear, I’d just cut another piece and replace it.
First I had to machine the center section of that Ryobi saw. It is not meant to have a sled. It has a sliding table on the side but that is too ” off center” for mounting a sled to. So, I set up some fences parallel with the saw blade and used a router and carbide bit to cut the sides of that aluminum housing to make it truly parallel with the blade. Then I fit the sled to the size of the center section…...............Jim
#12 posted 10-25-2012 01:04 PM
Sounds like most of you guys use wood runners.
I’ve seen those table saws with sliding tables, they look cool! Yeah, that is strange that your table saw doesn’t have slots in the table.
#13 posted 10-25-2012 01:20 PM
AJ, I rip the wood to just shy of the depth of the slot. Then I flip that on it’s side and rip it to the width of the slot. That gets me a runner that with edge grain on top and bottom, if it expands, it should expand mostly in the vertical direction, which is why I left it a hair short (it doesn’t need to ride on the bottom of the slot). I like to rip the width so it’s tight in the slot. One or two passes with a sanding block until it slides nicely will give you a runner with no wiggle room.
View oldnovice's profile
6664 posts in 3297 days
#14 posted 10-25-2012 03:16 PM
On a TS with a cast iron top almost any material will work. On an aluminum top, don’t use aluminum runner.
I use steel bar stock that fits perfectly, better than the original, in my 40 year old Craftsman. I have four pieces of that stock!
I have used UHMW runners for some jigs.
Never used any wood runners … no reason why!
Never used aluminum … !
View Zinderin's profile
94 posts in 2062 days
#15 posted 10-25-2012 05:39 PM
I use hardwood or polyethylene (when I can get it) ... my philosophy is simple …
a) I’m cheap,
b) I usually redesign or re-purpose jigs long before the wood wears out, and
c) I just don’t like the idea of metal on metal with my miter-slot … I’m ‘skeered’ it will cause slop.
Hardwood with a little bee’s wax … its awesome in my book.
