Delta 50-775 dust collector acting up...
Forum topic by nwbusa posted 10-24-2012 11:29 PM 1826 views 0 times favorited 3 replies Add to Favorites Watch
View nwbusa's profile
nwbusa
1021 posts in 2283 days
10-24-2012 11:29 PM
Topic tags/keywords: dust collector delta 50-775 motor noise
Hoping someone here may have run into a similar problem and can help identify a solution.
My Delta dust collector has always been trouble-free, but today when I fired it up, I heard a high-pitched squeal when the motor came up to full speed. I am thinking it might be bearings but I’m not sure. I pulled the motor and didn’t notice any play in the shaft, but who knows? Again, the sound only happens at full speed. Any advice is appreciated. Thanks!
-- John, BC, Canada
3 replies so far
View MonteCristo's profile
MonteCristo
2099 posts in 2185 days
#1 posted 10-24-2012 11:38 PM
Hi John:
If it’s a bearing, you’ll know pretty soon; ie. it’s gonna get worse in a hurry. I have 4 1200 cfm Delta collectors and the only problem I have had is that they all had to be switched to 220V in order to start.
Maybe a bit of debris is jambed in by the impellor and is rubbing when the collector is running ??
nwbusa
#2 posted 10-25-2012 12:04 AM
Thanks Dwight, I pulled the motor and blew everything out, although it didn’t look that bad in there. Reassembled and squeal is gone, but now I think I hear a slight rattling that wasn’t there before. Might be phantom noises at this point. You know how it is when you’re chasing down an engine tick, etc. We’ll see what happens.
-- John, BC, Canada
View RussellAP's profile
RussellAP
3104 posts in 2283 days
#3 posted 10-25-2012 12:53 AM
Probably got a wad of wood in there.
