| Forum topic by KevinBlair | posted 236 days ago | 1492 views | 0 times favorited | 52 replies | ![]() |
236 days ago |
Topic tags/keywords: ryobi battery porter cable battery question I know that the problems with Ryobi batteries have been the subject of much discussion. I have just had my last day of frustration with them. Freshly charged, not too old old, 18v lithium-ion battery in my circular saw. I needed to make a series of 12” cuts (probably 12 cuts total). I got two of them done; the battery quit as I started the third. So, how are the PC batteries vs. Dewalt vs any of the others? I am a home hobby user for the most part. Some cabinets (making kitchen cabinets is the major project right now) and small furniture as well as general home repairs are my primary uses. The above type of thing: 12 12” cuts, would be on the high side for me on any given day. You’d think Ryobi would be the right fit for my kind of use, but I really think I spend more time charging them than using them. I am thinking of using the CPO reconditioned site. I have bought a few things from them and have been very pleased. Thanks in advance for your thoughts and input. |
52 replies so far
#1 posted 236 days ago |
Give up on crap Ryobi stuff. I finally broke down and bought a Makita driver/drill 18v Lion after farting around with DeWalt batts. I’d buy it again but, for a circular saw, I stayin’ with a corded unit. -- bill@magraphics.us |
#2 posted 236 days ago |
I use a Porter-Cable cordless drill and the 18v batteries hold up just fine. I bought a second battery to have in the charger and ready to go when the one I’m using starts to slow down. Ryobi products are OK for fast, easy work…kinda a household product and not woodworker quality. -- 'The lyf so short, the craft so long to lerne.' - Chaucer |
#3 posted 236 days ago |
I have been very pleased with my Milwaukee 18v li-ion battery powered drill and impact driver tools. You need a corded circular saw for work in the shop. If I was out contracting and working on job sites all day then maybe I could justify a battery saw. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 236 days ago |
When you get tired of big store nonsense, and you add up the useless |
#5 posted 236 days ago |
Rigid. Lifetime warranty even covers batteries. |
#6 posted 236 days ago |
I use a Dewalt 20V circular saw for breaking down sheet goods, quick crosscuts, etc. and it works great. That said, Joe makes a good point regarding the Ridgid tools—battery replacement warranty is not to be undervalued. I’ve had good luck with all of my Dewalt and Ridgid tools, and I have more than a few of each brand. -- John, BC, Canada |
#7 posted 236 days ago |
I’ve never had a cordless tool die; it’s always the batteries. By the time they do give out, they are impossible to find or they are absurdly expensive. I didn’t even look at anything else other than the Ridgid when my Milwaukee finally stopped charging. I got the combo with the drill/driver and the impact driver for 179.99. This will probably be the last set I own. |
#8 posted 236 days ago |
So far my PC and DeWalt batteries are running neck and neck….what surprises me is my 20+ year old Makita’s still take and hold a charge !! Mistakenly bought a Craftsman set-up and never got any real use out of it at all , even though it was 18 volts : ( -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#9 posted 236 days ago |
Thanks guys! It looks like almost anything other than Ryobi will be an improvement. I am going to check out CPO. The life-time warranty from Rigid sounds good, but it seems PC and Dewalt are fine. I understand the Festool recommendation, but I think that is overkill for my level of use. Like NWBUSA, my primary use of the circular saw is to break down sheet goods. I have a corded saw, but I find it harder to control than the smaller 18v saw. I can keep the 18v saw tight to the guide and get a near perfect cut. I know I could get the Festool or Dewalt track saw, but that takes us back into the overkill for a home/hobby level. There are a lot of negative reviews of the Ryobi batteries, including their Li-ion ones. I didn’t do any real research before buying the Ryobi combo kit on sale a Christmas or two ago for something like $89.00. I think I have gotten my $89.00 worth and will keep using the drill, worklight, and even the vacuum that came with the kit. |
#10 posted 236 days ago |
kevinblair …..... i am a big ridgid fan. between myself and two family menbers, we have 15 combo kits and cordless power tools. THERE IS NO LIFETIME WARRANTY ON RIDGID HANDHELD AND STAIONARY POWER TOOLS. here is their warranty and what the LSA (lifetime service agrement) is: http://www.ridgid.com/tools/power-tool-warranty the lsa is available to the original owner of new qualifying tools. if your purchase from CPO is for a reconditioned tool, i believe such tools are ineligible for ridgid’s LSA. buying any other brand other than ridgid is, IMHO, foolish as all batteries eventually fail. ridgid’s LSA covers batteries, provided the new tool is properly registered with the program. i have never had a problem with the registration process. but then, i determined what the rules for successful registration were and followed them. -- there's a solution to every problem.......you just have to be willing to find it. |
#11 posted 236 days ago |
Toolie, I completely agree. To me a cordless driver is a cordless driver. I’ve had just about every brand there is (except ryobi or HF). None completely blew me away, none completely sucked. Once I found out abut the Ridgid LSA any other brand was not even a consideration. I’ve got about 6 perfectly good cordless drivers that I spent over $100 on with completely dead batteries in my basement. Replacement batteries either aren’t available, or about $20 less than a new tool. You can have batteries rebuilt, but again the cost is prohibitive. |
#12 posted 236 days ago |
If you want to make sure the battery doesn’t crap out on you. Don’t use cordless tools. Pretty simple solution if you ask me… I’ve had cordless tools from Ryobi, Skil, B&D, Makita, and Ridgid. The BEST battery life I got out of any of them is with the green Ryobi 18V whatever the tech is on those… But generally speaking, cordless tools are IMHO mind you, sub par for anything you need reliability for… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#13 posted 236 days ago |
I agree there as well. Cordless drivers are the only cordless tools I own. I am not a big fan, but a cordless driver is really a valuable tool. I can get in places I simply cannot access with my Milwaukee magnum or my Makita corded driver. |
#14 posted 236 days ago |
I am going to check out Rigid today at Home Depot. CPO has a PC combo (driver and Circular saw) package on sale for $80.00. Hard to beat that price. I agree that the cordless drill/driver is the best use of these tools. The worklights also seem fine. I have not been impressed by the 18v saw or the vacuum in comparison to the corded models. That said, I have experimented with cutting sheet goods with my corded circular saw and it always seems to wander quite a bit. This means for me, more waste, as I have to cut the boards wider to account for the wandering before final cutting on the table saw. This seems to be a standard problem, solved by the purchase of a track saw system (Festool or Dewalt). Using the 18v circular saw is slower (especially when the batteries give out after a few minutes), but a lot easier to control. I am confident in making my cuts as little as 1/8” wider than needed as opposed to a couple of inches with the corded saw. I have heard really nice things about Festool and Dewalt track saws, but either one would sit around the shop for months and months w/o any use. I want to get a good quality dovetail jig amongst other upgrades and would rather spend the money on those than on a track saw. I will check this out today, but do either Rigid, Dewalt, or PC offer a corded adapter for their tools? Ryobi does not. An adapter would seem to offer the best of both worlds. |
#15 posted 236 days ago |
Makita 18v Some of mine are 5yr old and I run six batteries I buy when there is a special, like machine plus 3 batteries. -- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe |
| Forum | Topics |
Woodworking Skill Share
8844 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1599 |
3593 |
15974 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2773 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6131 |
