Is it possible to adequately air dry 8/4 lumber?
Forum topic by yellowtruck75 posted 10-24-2012 09:29 PM 3373 views 0 times favorited 13 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 2973 days
10-24-2012 09:29 PM
I have quite a bit of 8/4 walnut and cherry, these are slabs that still have the bark on them. I have the wood stacked and stickered in my basement. The walnut has been stacked since March and the cherry has been there since Sept. I checked with my local mill and they are willing to kiln dry it for $700 which isn’t alot when I break it down per slab. Is it possible for me to leave them where they are and that they will adequately air dry? I know that 8/4 will take roughly 2 years which I can stand but I don’t want to wait the time and check the surface with my moisture meter and then have it split later on.
Thoughts?
13 replies so far
View pintodeluxe's profile
pintodeluxe
5568 posts in 2719 days
#1 posted 10-24-2012 09:46 PM
Regardless if you decide to kiln dry them or not, 8/4 should air dry 2 years before it enters the kiln. If wood goes in the kiln too wet, it will warp and check. It creates internal stress and cracks in the wood that you simply can’t sand out.
By the way, you could build a dehumidification kiln for less than $700. I have $150 into my portable kiln that will dry 200-300 b.f. at a time.
yellowtruck75
#2 posted 10-24-2012 10:25 PM
Do you have a link or pictures of a dehumidification kiln? Would you suggest the wood air dry for 2 years before using a dehumidification kiln also?
View crank49's profile
crank49
4029 posts in 2877 days
#3 posted 10-24-2012 10:43 PM
Also, consider that another reason for kiln drying is to kill bugs.
I have 550 BF of 8/4 cherry air drying in my basement right now.
I recently re-stacked it to flatten out some of the boards that were wanting to twist.
In that process I discovered little holes and pi;es of sawdust on some of the boards.
It’s my understanding that powder post beetles don’t lay eggs in the heart of cherry, but prefer the sap wood.
I don’t know if that is true for walnut, but is something you might want to consider.
I plan to build a dehumidification kiln. I also plan to rig up a way to heat the stack to 150 degrees or so to kill the bugs. Although, when you fine the holes, like in my case, they have already done the damage.
View WDHLT15's profile
WDHLT15
1722 posts in 2382 days
#4 posted 10-25-2012 04:04 AM
In Georgia, 8/4 cherry will air dry much faster than 2 years. More like 1 year or less. Cherry dries fast. A moisture meter is your friend. Your climate may vary.
View derosa's profile
derosa
1572 posts in 2742 days
#5 posted 10-25-2012 04:42 AM
Really depends on the basement. If your furnace is in the basement and completely dries the basement like mine does in the winter then there is a possibility that by the end of the winter the boards could be close to ready.
-- --Rev. Russ in NY-- A posse ad esse
View Joe Lyddon's profile
Joe Lyddon
10038 posts in 3958 days
#6 posted 10-25-2012 05:21 AM
I’ve had a basement once… During that time, I found it the coolest part of the house…
I would think Ventilation & Dehumidification would be the most important things to ensure any drying at all.
Maybe a little heat is required if it’s very cold in there… especially during winter.
Cost-out doing that plus the electricity required… then put a Value on the Space being used & add it to the Total… worth using the space for something else? Compare that cost to having it dried elsewhere.
View Wildwood's profile
Wildwood
2240 posts in 2041 days
#7 posted 10-25-2012 01:56 PM
Drying wood simply a water removal can sum up this process in one word evaporation. Air circulation more important than heat for air-drying wood in your basement. Adding an inexpensive fan or two & optional timer should help drying your wood. Based upon current MC of boards can set up a schedule of fan on, fan off. Fan speed and placement easy learning process. Just getting air circulation through stack all you want.
I bought this MM from Lowes couple years ago when only cost $10, and recommend it at current price. Reviews at website worth a look.
http://www.lowes.com/pd_78059-56005-MMD4E_0__?productId=3136919&Ntt=moisture+meter&pl=1&currentURL=%3FNtt%3Dmoisture%2Bmeter&facetInfo=
-- Bill
View pmayer's profile
pmayer
1017 posts in 2971 days
#8 posted 10-25-2012 03:20 PM
In Minnesota I can get 8/4 cherry or walnut down to 10% in one drying season (April to October) as long as I store it indoors. I also use a fan and sometimes a dehumidifier. The only time I bother with the dehumidifier is when I am drying a large quantity and I am concerned about all of the moisture building up in the room.
View Nomad62's profile
Nomad62
726 posts in 2864 days
#9 posted 10-25-2012 10:33 PM
It depends on a lot of variables, but for the most part you should be okay. They should air dry just fine, provided the mc in the basement is the same as the rest of the house; if it’s warm down there you should be okay. The cherry is the wild card, it likes to crack and has more of a tendancy to attract and harbor bugs. The walnut will be forgiving, but the sap wood on both will invite bugs of all sorts especially ants. If you plan on using the live edges in your project you should get the kiln work done soon; if not, cut it off and get rid of it. I’d pressure wash the bark off if you keep the sapwood on. The heartwood is generally safe. There are many opinions on when and how to kiln dry, mine is to let it air dry 6 months to a year then kiln dry/sterilize it down to a couple percentage points lower mc than you expect the wood to be in after you use it.
View RussellAP's profile
RussellAP
3103 posts in 2192 days
#10 posted 10-25-2012 10:58 PM
If you sticker it in your basement, keep it 10” off the floor and I’d use a vapor barrier and a fan on low speed. Be sure to coat the ends. I’d cut off half an inch on the ends and then seal them.
WDHLT15
#11 posted 10-26-2012 02:30 AM
There is a lot of water in wood, so if you use the basement, you might get mold and mildew in the basement and rust on tools. I think the dehumidifier would be a good bet.
View MonteCristo's profile
MonteCristo
2099 posts in 2094 days
#12 posted 10-26-2012 02:42 AM
Air drying is a safer bet if you have the time – not only does kiln drying increase your costs, they can screw it up and trash the boards if they don’t do it right . . .
yellowtruck75
#13 posted 10-26-2012 11:48 AM
I talked with the local mill and I am going to take the walnut and cherry to the kiln over my Thanksgiving vacation. I hate spending the money to get it kiln dried but at this point I am buying other walnut and cherry to do project while this is air drying. I haven’t checked the moisture in a few months so once I do I will post the results here.
