New Band Saw
Forum topic by bbqking posted 114 days ago 236 views 0 times favorited 7 replies Add to Favorites
View bbqking's profile
bbqking
279 posts in 260 days
114 days ago
Topic tags/keywords: bandsaw blade
I have decided to buy a new bandsaw to help out with tenons and some curved pieces I make. My old saw is nothing to speak of, a cheap benchtop model. I am probably going to buy a Grizzly model GO555. My question is about blades. I don’t know that much about bandsaws. I want a blade that will leave a nice, smooth cut, without any tearing or bits of wood drawn through and hanging on by a thread. Also I want a blade that will cut true without bending or deflection. I’m sure this has something to do with the saw itself and the rollers & etc. I will be sawing 2” stock max and 1/2” stock min. How many TPI, what gauge, how wide? Also, I need help on what’s a raker, skip, hook, and like that. I realize it’s a type of tooth (maybe), but what do I want? I build with white oak, red oak, and walnut. Also, what about speed & etc.? Help me out on this but please don’t send me to a site to watch a movie. I trust you guys & gals more than an online video. As always, bbqKing
-- bbqKing, Lawrenceville
View lew's profile
lew
1751 posts in 292 days
114 days ago
I am no expert with band saws and I am sure others here can give you more in depth knowledge.
From my limited experience, the more teeth per inch (tpi) on a blade, the smoother the cut. However blades with lots of teeth will cut slower. The guides/rollers will help prevent deflection along with the proper blade tension. But remember the more narrow the blade, the smaller the radius that can be cut, however the narrower the blade, the more difficult to cut a straight line.
For aggressive work, such as resawing, the widest blade your saw can handle with the fewest tpi will probably work best. Check the manual to see the max width specs for your saw. Also, for resawing, I have heard that a carbide tipped blade is really great but EXPENSIVE! Skip tooth blades are usually used for resawing and hook tooth for hard woods.
I have pretty good luck with Timberwolf blades form Woodcraft.
Hope this helps.
Lew
View GaryK's profile
GaryK
8558 posts in 525 days
114 days ago
This is the blade you want:
http://lumberjocks.com/reviews/76
Get the 1/2” and you’ll never look back.
View CedarFreakCarl's profile
CedarFreakCarl
400 posts in 590 days
114 days ago
All BS blades are going to deflect a little and give you some drift. The wider the blade the less drift you’ll have. Drift is no big deal and the Wood Whisperer has a pretty good video showing how to adjust your fence to account for it. Basically you just pencil a straight line parallel to the edge down the middle of say a 2×4 24” or so long and saw along that line to about the midway point and stop the saw and don’t move the board. Then you just match up your fence to the edge of the board.
As far as blades go, for resawing, you’ll probably need a 3 or 4 tpi blade. 3/4” will work better than a narrower blade for resawing, but I usually use a 1/2” so I don’t have to change it out to make an occasional curved cut. I’ve got an 18” BS that will take up to an 1 1/4” blade, but haven’t put a wide one on it yet.
You’ll want to get a good quality blade such as Timberwolf or Woodslicer. I haven’t tried a Woodslicer, but I can vouch for the Timberwolf. It’s a great blade. If you want smoother cuts on your curved stuff, you can get a 6, 8 or 10 tpi in blades as narrow as 1/8”. Well, that’s what’s worked for me, good luck! Carl
-- Carl Rast, Pelion, SC
View SawDustnSplinters's profile
SawDustnSplinters
140 posts in 318 days
114 days ago
I got to admit I don’t know much either but with the help of a couple of books I understand them alot better and know a little about super-tuning them. I bought an inexpensive Ridgid 14” a couple of years ago for 349.00 at HD and put a grizzly riser block that I had to modify on it, replaced the tires with some Carter’s tires, I use a 1/2 ” TimberWolf blade for most work, and put in cool blocks which were invented by the latter author in below links to books. This saw has worked great for cutting tenons, and that is all I really use it for. My plan is to one day use it for other things like resawing that is why I bought the riser and a 3/4” Timberwolf blade from Suffolk Machinery. When I called Suffolk Machinery and told them what woods I was mainly working with they helped me select the right blades. They also had a buy 3 and get one free which they have going on now. So I got a 3/16”, 1/4”, 1/2”, and a 3/4”...
Most of the reviews I have seen on your Grizzly Bandsaw seem good and in hindsight it is only a few bucks more then what I got and I probably should have bought that one but until I read thru the books which I bought later, I could not have made an informed decision. So I reccommend reading thru the books to help you get the most bang for your bucks…They had both for 25.?? on Amazon.com
http://www.suffolkmachinery.com/
The Bandsaw Book [ILLUSTRATED] (Paperback) amazon.com
by Lonnie Bird
Band Saw Handbook (Paperback) amazon.com
by Mark Duginske
http://www.amazon.com/Grizzly-G0555-Ultimate-14-Bandsaw/dp/B0000DD0AC/ref=cm_cr-mr-img
Good Luck
-- Frank, Little River/Academy, Texas , http://www.allthingsrustix.com
View John Gray's profile
John Gray
882 posts in 422 days
114 days ago
Gary is right “This is the blade you want:
Get the 1/2” and you’ll never look back.”
View motthunter's profile
motthunter
1234 posts in 336 days
114 days ago
Gary is correct… first thing, throw our the grizzly blade.. great saw comes with a sharp band that some may mistake for a blade. Enjoy your new saw..
-- making sawdust....
6716 posts in 388 days
113 days ago
Good luck with your purchase King. Will have to call you the bandsaw buddy. LOL
Bookmark And Share This Page
