| Forum topic by DeansDust | posted 206 days ago | 904 views | 1 time favorited | 19 replies | ![]() |
206 days ago |
Well, here I go. I’m gonna put a 3/4” floating plywood floor down on my concrete flloor. Not gonna use any sleepers, and not gonna use tongue and groove either…just good ol’ 3/4” AC grade plywood. I did a vapor test in my shop by duct taping a 14” x 14” square of heavy mil visqueen and observed for the last 10-12 months that no moisture or condensation formed under the visqueen. Alas- no moisture or condensation formed. Far out!!! So now I am gonna lay down a nice heavy felt paper over my 30’x40’ concrete shop floor to float my plywood on. The slope inherent to most shop floors is negligable…so I won’t sweat that part. I am gonna use unglued biscuits and with good clean square panel cuts to keep my floor flat and fit- and to allow moving and shrinkage. Now then, could a fellow jock tell me what I’m over looking? Please talk me out of anything that seems stupid with my floor project! Thanks for any interest:) Deaner -- Once harm is done, even a fool understands it. Homer |
19 replies so far
#1 posted 206 days ago |
Good prep, Deaner. How small are you going to cut the ply? If there is any bowing in the sheets, the smaller the better I would suppose. There will be no shrinkage with the ply indoors. I’m envisioning the biscuits being stapled in from the top. It wouldn’t be a super joint, but it would keep it all together as you assemble. If you alternate grain direction it would look pretty cool….until you start putting machines and benches and cabinets on it! In summary, I’d say go for it, and again kudos for your prep and thought. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#2 posted 206 days ago |
As Lee said keep the sheets size to 4×4 or 2×4 as recommended by the NWFMA. I would at least seal the underside of the plywood and the edges. Stagger your joints when laying the plywood and allow a minimum of 1/8” gap between panel edges. There is an “Underlayment Grade” plywood that is not T & G. The underlayment grade doesn’t have any voids in the core. -- Don, Pittsburgh |
#3 posted 206 days ago |
Thanks Lee, Good idea on the staples. That’s all it would take….if anything at all is used. I think you are right about a couple things: I’d prefer to use full sheets for fewer seems, with 2×8 sheets around the perimeter against the walls. By not gluing anything, I could still pull up indivdual panels in the event of damage, wear or need for access. The idea of using smaller panels alternating direction , i.e. 2×2 pieces, is saavy and would be just as you said: cool:) I calculated that I need 20 sheets of plywood…and that translates into many fewer cuts…and that in turn would translate into 80 cuts if I used 2×2…and only 40 if I use 4×4 panels. Either size would be great, no? So OK: you talked me into smaller squares with alternating grains Lee! Cool indeed- thanks! I’ll be posting pics of the project pretty soon, as I find it interesting how little info is actually posted out there. taker’ easy- more soon! -- Once harm is done, even a fool understands it. Homer |
#4 posted 206 days ago |
Good suggestions Don. I’m gonna look for the “underlayment grade” plywood. Lordy, it couldn’t be any more expensive in my neck of the woods (WA) than the 23/32” AC ply I’m using from Home Depot…could it? LOL. Clarification please: 1/8” gap between every panel edge…or…1/8” gap just between outside panels and the wall? Wouldn’t a bunch of 1/8” gaps at 2’x2’ apart seem…I dunno…odd? I appreciate your interest Don. -- Once harm is done, even a fool understands it. Homer |
#5 posted 206 days ago |
I would glue the biscuits and panel edges together but leave 1/2” away from the outside walls for movement. Otherwise you will have movement in different directions and gaps where you are working/walking. -- Sam Hamory - The project is never finished until its "finished"! |
#6 posted 206 days ago |
Good call Sam- I see what you’re saying. Especially when sliding stuff arond on the plywood floor. HONEY- grab some Gorilla glue when you hit Home Depot! Oh- and don’t worry about the 20 sheets of plywood, I’ll get the kids for that;) -- Once harm is done, even a fool understands it. Homer |
#7 posted 206 days ago |
Consider 3/4” T&G Advantech decking. IMO, it’s superior to ply, and costs less. -- Clint Searl.............We deserve what we tolerate |
#8 posted 206 days ago |
Indeed I will consider that Clint. I’ll look for it. Thank you:) -- Once harm is done, even a fool understands it. Homer |
#9 posted 194 days ago |
Well Jocks, I began with 10 sheets, cut them into eighths, table sawed each side on each eighth for squareness and size; the set up a production jig to biscuit each side with 3 biscuits…anybody doing the math??? LOL I then arranged them in a checkerboard fashion, again, 3 biscuits per side and gorilla glued the only the corners. I’m BEAT! Now I got to apply a finish to this section of floor so I can move things back into place to begin the next 1/3rd section. -- Once harm is done, even a fool understands it. Homer |
#10 posted 194 days ago |
I think it looks great! -- Brian |
#11 posted 194 days ago |
Thanks Brian- the proof will be in the puddin’. -- Once harm is done, even a fool understands it. Homer |
#12 posted 194 days ago |
I would use oil based poly, but thats just me. I did a ton of reading on a hardwood flooring site about 3 years ago and Bona Traffic was considered the way to go for water based. -- Brian |
#13 posted 194 days ago |
I used spar urethane on my shop floor, it’s durable, easy to sweep and easy to wipe up spills and stains. -- Rob, Sault Ste. Marie, Ontario |
#14 posted 194 days ago |
pretty expensive solution for a shop floor! but since you started, oil base anything if you can open the doors and let it dry dust-free. or maybe one of the garage floor epoxy coatings. personally I would have cleaned the concrete and applied the epoxy coating…a mess and it stinks but it works. |
#15 posted 194 days ago |
I recently moved my entire shop including the floor. I had 3/4” tongue and groove ply floor screwed down onto floating 2×3’s. In my new shop I just put the same ply, plus some needed in this slightly larger shop. This time I just layed it down on the concrete floor that had a glued down felt rug cushion. IT went in quickly and I like it. I put no finish on this floor at all. -- In God We Trust |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15750 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
