Well now what???
Forum topic by Chad0125 posted 10-24-2012 02:09 PM 798 views 0 times favorited 5 replies Add to Favorites Watch
View Chad0125's profile
11 posts in 1995 days
10-24-2012 02:09 PM
Topic tags/keywords: finish maple burl turning maple
hello all -
A guy at work brought me a maple burl to turn into a bowl (this is one half of it) so as i got started and revealed what was underneath I came into some cool spalting and knots. The question is he wants the “all natural” look and would prefer not to fill the holes/knots/or cracks with epoxy/CA/or stone etc…So if i go this route and just use some tung oil finish followed by laquer or wax everything should look ok???
thanks in advance
5 replies so far
View Bill White's profile
Bill White
4872 posts in 3889 days
#1 posted 10-24-2012 02:12 PM
If you use a tung oil “finish” you might not need anything else but the wax.
View Wildwood's profile
2264 posts in 2063 days
#2 posted 10-24-2012 02:29 PM
Assuming you are talking about pure Tung oil, agree should not need anything other than wax on top of Tung oil. Only down side to pure or polymerized Tung oil is drying time. Just follow instructions for thinning with naphtha, mineral spirits, turpentine, or citrus solvent to speed up drying time.
I do not like using oil blend products end up throwing away lot of unused finishing material.
If want more than satin finish do not use Tung oil, use lacquer.
-- Bill
#3 posted 10-24-2012 03:00 PM
thanks for the quick replies. so he also mentioned wanted shiney, so as i am new to the whole bowl finishing process just go ahead and finish with laquer? i assume they make a wipe on laquer that’s shiney and if you use just laquer do you still need a wax also, so many choices to finish…
#4 posted 10-24-2012 08:15 PM
Uploaded pictures of burl
View Surfside's profile
3389 posts in 2102 days
#5 posted 10-24-2012 09:11 PM
Yes. Better go with oil finish because the natural luster, or glow, of wood under an oil finish is very attractive.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
