Rip & rosscut 3"+ Hard Maple
Forum topic by steve6678 posted 10-24-2012 12:14 AM 803 views 0 times favorited 5 replies Add to Favorites Watch
View steve6678's profile
438 posts in 1996 days
10-24-2012 12:14 AM
I’ve never had to rip and crosscut 3”+ hard maple. I do NOT have a BandSaw.
I have a TS, my chop saw won’t touch it.
Can I Rip 48” lengths of 3” Maple on my Table Saw (1 1/2hp 10” 20 amp circut)?
Gonna try, regardless, have no choice…Hmmm
I’ve noticed binding (pinch) in smaller rips, so I inserted a shim right after the cut as it progressed through the table
-- Steve - Dust sucks!
5 replies so far
View Loren's profile
10114 posts in 3584 days
#1 posted 10-24-2012 12:22 AM
You may want to do it in two or more passes at different
blade elevations. You can flip the work as well. Whatever
you do, the cut won’t be clean with the equipment you
have so the edges will need jointing.
13598 posts in 3277 days
#2 posted 10-24-2012 12:24 AM
i ‘re-saw’ with the TS all the time to 6”
then thru the planer
(i rip thicker by up to 1/8”
as the blade might ‘tilt’ thru the cut sometimes)
in hardened wood
sometimes it’s best to do in 1” rises
go easy
flip end over end
not edge over edge
run thicker stock thru the jointer
(if you are using 12/4 stock)
after each re-saw
to get another flat
and re-saw again
the same way
View WDHLT15's profile
1726 posts in 2412 days
#3 posted 10-24-2012 12:48 AM
Get a new Forrest Woodworker II blade. That will cut it on your saw. A dull blade will make your life miserable.
-- Danny Located in Perry, GA. Forester. Wood-Mizer LT40HD35 Sawmill. Nyle L53 Dehumidification Kiln.
View saucer's profile
61 posts in 2883 days
#4 posted 10-24-2012 12:57 AM
I use a skill saw to get the pieces small enough to run them through the table saw when i have oversize material..
-- It has been deemed bad for you hence there for it is illegal.
#5 posted 10-24-2012 01:07 AM
ha, thanks.
I just retired a Forrest WWII, and got a RIDGE TS2000, I respect Forrest and have used one for years, resharpening is awesome, but when I was introduced to Ridge I was surprised at the comparibility, I tested them both and found the Ridge to be a better performer, undeniably smother, more fluent cuts, I honestly mean “like butter”, a Premo blade, Brand New still, So I guess until I try to Rip that Hard Maple-huge-massive-lumber, I won’t know, huh, thanks WDHLT15
