| Forum topic by Woodendeavor | posted 237 days ago | 1051 views | 1 time favorited | 10 replies | ![]() |
237 days ago |
I had some pieces of flame birch left over and decided to do a little experiment with them. P.S. please don’t tell my wife I used the stove to make sure the legs were all on the same plane |
10 replies so far
#1 posted 237 days ago |
Super Glue… -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#2 posted 237 days ago |
The only thing that comes to mind is something like what Marc Spagnuolo did on his end table build. -- -=Pride is not a sin=- |
#3 posted 237 days ago |
cut them so they are parallel to the floor…then a dollop of clear silicone… |
#4 posted 237 days ago |
Ditto on the silicone. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#5 posted 237 days ago |
How permanent a fixing do you want? If the table is never going to be moved, I would use the clear bumpers Jonathan mentioned, the top simply sits on and the bumpers have a good enough grip that the glass will not move from minor knocks. I’m not sure about the silicone because it’s never crystal clear – you might make a mess cleaning up the excess as well. There’s this product too; http://www.amazon.com/Quakehold-33111-Museum-Gel-Clear/dp/B0002V37XY Whatever you decide, it would be best to try it first on a test piece. Dan Mosheim posted a great table here – maybe you could ask him. http://lumberjocks.com/projects/56597 -- Never trust a man in winklepickers |
#6 posted 237 days ago |
You could let the glass just sit on the silicone. The silicone will actually attach the glass unless you let the drop cure for about a week before putting the glass on it. When you do put the glass on the silicone, sprinkle a bit of flour on the silicone, just to make sure it doesn’t stick. Nice looking pile of sticks you got there. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 237 days ago |
Duct tape would work. -- Bondo Gaposis |
#8 posted 237 days ago |
I have used LEXCEL clear caulk for attaching glass to wood for over 25 years. Far better than silicone! It is extremely clear and does not peel out in a strip like silicone will after some time. It has some stretch to it after it dries. -- Fine Custom Woodwork since 1978 |
#9 posted 236 days ago |
Thanks for the advice, I like the look of the square cut corners too much to cut them off to support the glass…Thinking about a small glue block on the inside of the legs to support glass. |
#10 posted 236 days ago |
You crack that stovetop and you’ve got bigger probs than a tabletop. :) -- bill@magraphics.us |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
