Paraffin wax
Forum topic by RussellAP posted 208 days ago 714 views 0 times favorited 13 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 453 days
208 days ago
Does anyone ever use this stuff? Paraffin wax.
What is it used for?
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
13 replies so far
View Gene Howe's profile
Gene Howe
3184 posts in 1595 days
#1 posted 208 days ago
My mother used it to seal jelly jars.
I’ve used to to lubricate screws. A toilet wax ring is easier to use, though.
It’s no substitute for sharpness, but it does help hand saws slide through the wood.
I’d imagine it would work well to lubricate any metal to metal or wood to wood (i.e sliding dovetails) applications.
View hairy's profile
hairy
1763 posts in 1698 days
#2 posted 208 days ago
I use it. It’s a good lubricant on jigs that slide, it keeps glue from sticking to what you don’t want it sticking to. I put it on screws. I have used it as a friction finish on lathe turned things.
-- It must be jelly baby, cause jam don't shake like that...
View dhazelton's profile
dhazelton
828 posts in 463 days
#3 posted 208 days ago
I have a few blocks of it from the canning supply area of the supermarket. I use it to lubricate wooden drawers where they ride on runners. Sticky wooden windows as well. You can shave it with a grater and dissolve it in mineral spirits if you want to make your own Thompson’s Water Seal type product.
View MedicKen's profile
MedicKen
1560 posts in 1628 days
#4 posted 208 days ago
I use it for lubricating cast iron surfaces, hand plane soles, jointer tables, planer tables etc. It is nice because it lubricates well, will not interfere with finishing like other waxes.
View jap's profile
jap
1029 posts in 220 days
#5 posted 208 days ago
agrees with all of the above
-- Joel -- http://diversitywoodworks.wordpress.com
View Wildwood's profile
Wildwood
343 posts in 301 days
#6 posted 208 days ago
I use it to end seal turning blanks, and sometimes as coolant when drilling on lathe. As wood loses MC and shrinks wax may or may not develop cracks. So not a set it and forget it method of end sealing wood.
If fully enclose wood in wax, it will not lose moisture.
-- Bill
View Blackbear's profile
Blackbear
54 posts in 385 days
#7 posted 208 days ago
I have used it on the table saw, although now I use Johnson’s past wax instead (easier application). The Gulf wax worked really well, but you had to really buff it in so it would sort of melt on the surface. It did work really well however.
Recently I melted some down and used it to seal the ends of some lilac my Dad just cut for drying. After reading the post above by Wildwood I’ll have to keep an eye on the boards. They are fairly small though so I wonder how much they will actually shrink.
View Broglea's profile
Broglea
654 posts in 1257 days
#8 posted 208 days ago
I’ve used it on drawer slides and cutting boards.
820 posts in 659 days
#9 posted 208 days ago
All the above, but it really impressed me once applied to the sole of a hand plane. Sheesh! The effort decreased by 75%.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Grandpa's profile
Grandpa
2380 posts in 842 days
#10 posted 208 days ago
besides the above I have used it in making my own finish stripper. I have a recipe that calls for some ugly stuff that has melted parafin as the agent that makes it cling to the piece being stripped. It worked well, but I no longer make it because of breathing the fume of the ugly stuff and there are now better strippers on the market.
View Tedstor's profile
Tedstor
924 posts in 799 days
#11 posted 208 days ago
Ahhh Paraffin wax. In addition to the above I use it to lube bandsaw blades, vise screws, tablesaw trunions, door hinges, and pretty much anything else that needs a persitant lubricants that resists dust.
4 bucks gets you a four bar package in any grocery store in the world. I’m not sure why everyone doesn’t have a box.
View ddockstader's profile
ddockstader
78 posts in 1428 days
#12 posted 207 days ago
Rub on the inside and outside of glued corner joints (drawers, boxes, etc.)(where you DON’T want the glue to stick). Glue squeeze out can just be easily scraped off after it dries. Then the paraffin can be removed with mineral spirits.
View Gary's profile
Gary
3529 posts in 1599 days
#13 posted 207 days ago
It’s also used in some finishing wax recipies along with bees wax and carnuba.
