| Forum topic by gfadvm | posted 240 days ago | 560 views | 0 times favorited | 13 replies | ![]() |
240 days ago |
I have some redwood 1×12s that came from a really old house torn down in Ks. The problem I’m having is that it soaks up finish like a sponge! Three coats of undiluted Zinsser shellac and NO evidence of any finish on the surface. It just soaks in. Any thoughts other than to just keep laying on more coats? Thanks for looking. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
13 replies so far
#1 posted 240 days ago |
maybe let each coat dry some first you need to build a ‘dam’ -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 240 days ago |
“let each coat dry some first” Shellac dries really fast anyway but on this wood it is dry to touch in 1-2 minutes. Maybe put on 2-3 coats, leave it overnight and then try some more? I’m not married to the shellac if another finish would give me a semi-gloss with less hassle. Maybe some nice thick Spar Urethane? Always appreciate your input David. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#3 posted 240 days ago |
How about a sanding sealer…. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#4 posted 240 days ago |
I have used a medium-heavy coat of sanding sealer (and let fully dry) that I sprayed on. I finished with a lacquer semi-gloss top coat. The sanding sealer did the job. I had a whole pile of 1×6 reclaimed redwood. The lacquer by itself soaked in just like its doing to you. Sure does look good once its done! |
#5 posted 240 days ago |
I thought of sanding sealer as well. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#6 posted 240 days ago |
when sanding sealers first came out i am not sure these days all the hype from chemical manufacturers i got to the store i like the taste of lipstick gluckonthisgfadvm -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#7 posted 240 days ago |
Andy, I have had some luck with a nice thick coat of Minwax Tung Oil as my first coat or two on dry redwood. It soaks in but does seem to start a process of sealing. I let it dry a day or two between coats. Old redwood does really soak in the finish. If it has that chalky, powdery top layer I’d plane it first. -- Big Al in IN |
#8 posted 239 days ago |
I am a big fan of Shellac for many things. I use Miniwax Sanding Sealer before using Shellac and it always turns out great. Just let the Sanding Sealer dry over night! Nate -- "With a little bit of faith, and some imagination, you can build anything!" Nate |
#9 posted 239 days ago |
I haven’t finished redwood, but I have had some Mahogany that really soaked up finish. I used some Danish Oil and wet sanded the surface with the oil with 600 grit sandpaper. The result was a fine slurry that pushed into the pores and did a fair job sealing the wood. After a night of drying I then applied another coat with better results. |
#10 posted 239 days ago |
I thought sanding sealer was shellac (not sure just what it is now). I’ll try some as it was the most recommended solution. In the meantime I found sanding to 600 grit helps a lot (especially on the end grain). Is that sanding sealer compatable with all finishes or just???? Thanks for the suggestions all. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#11 posted 239 days ago |
I thought of sanding sealer too. Good luck! -- If I can do it.....so can you! -AJswoodshop |
#12 posted 239 days ago |
Totally agree with Patron – ”all the hype from chemical manufacturers Whatever you use, sand with at least a 220 grit paper before you put on the next coat. Sanding not only smooths the surface but also helps seal the surface, allowing you to start building up coats rather than having them soak in. If you’ve ever over-sanded an area (trying to remove a scratch or a spot of glue) then tried to stain the piece, the resulting light area where you’ve over-sanded is proof of this. -- Happiness does not come from doing easy work but from the afterglow of satisfaction that comes after the achievement of a difficult task that demanded our best. --Theodore I. Rubin |
#13 posted 238 days ago |
Haven’t tried the sanding sealer but sanding the wood to 600 grit and sanding the shellac is working very well. Maybe sanding to that fine a grit is burnishing the wood. Thanks for the input. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2104 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
