| Forum topic by Cole Tallerman | posted 208 days ago | 506 views | 0 times favorited | 10 replies | ![]() |
208 days ago |
so, ive decided to get a Bosch router. I would like to use it in a table, but also have a plunge and normal base. When im on the Bosch website, I see 3 options. I see the plunge and fixed base 1617, the fixed and table mount 1617, and the new MRC23EVSK. My understanding was that you can put any fixed base into a router table. What are the god things about the router table base? Will the new MRC23EVSK be good in a table? Here is the bosch website which has the three options. http://www.boschtools.com/Products/Tools/Pages/ItemResults.aspx?catid=1527 Thanks in advance! |
10 replies so far
#1 posted 208 days ago |
I recently bought the combo kit with the fixed and plunge base. I also built a router table to put it in, but got the top from a recent sale at Rockler. I found that with the fixed base with the wooden handles connected I really couldn’t get it to fit right under the plate that came with the router table top. The handles use some star shaped screw to attach to the base. I didn’t have the proper drive to remove the handles and I figured it would be easier to just get the router table base to leave it permanently attached to the table. Also, given my history I figured I would end up losing one of the handles anyhow. I think the router table base it just the fixed base with no handles. So I guess if I had to get one it would be the one with the plunge and fixed base and just remove the handles as needed. Since I was splurging on a new router and table I figured buying the 3rd base wouldn’t kill me. Jon |
#2 posted 208 days ago |
The most versatile would be the 1617 kit with the plunge base. Put the fixed base in the router table, use the plunge base for hand routing. -- He who dies with the most tools... dies with the emptiest wallet. |
#3 posted 208 days ago |
I read that the MRC23 had limitations in a router table – the collet doesn’t extend far enough the table for easy bit changes. The Freud FT1700 is great for a router table and offers full above-the-table adjustments and bit changes.. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#4 posted 208 days ago |
Due to your responses, this is my shopping cart. thanks everyone! |
#5 posted 208 days ago |
For $6 more, you could have a new one. That one is refurbished. Nothing wrong with it, just sayin’. I have the same router on my wish list for Christmas, and you may also want to consider the bushing/template kit. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#6 posted 208 days ago |
At a $6 difference I’d go for the new one as well. Also, you may not need the extra fixed base unless you plan on using the fixed base for hand routing a lot. IIRC, the base that comes with the kit has the above the table height change feature, including the wrench. -- He who dies with the most tools... dies with the emptiest wallet. |
#7 posted 208 days ago |
Cole, That is exaclty the combo I got. I haven’t really used it too much yet, but it is always a little reassuring when someone else does the research and comes to the same conclusion. Jon |
#8 posted 208 days ago |
Interesting on the bases. I wonder if there is anything different between the under-table featues of the PK combo set and in the standalone RA1165 base? I’m about to buy one of these routers for used under a table and have no need for the plunge feature—unless it’s needed for under-table travel. Details on this function are few and far between. |
#9 posted 208 days ago |
The under table features refer to the fixed base only. -- He who dies with the most tools... dies with the emptiest wallet. |
#10 posted 207 days ago |
i,ve had my 1617 for about 10years i guess…my best router…bought it from the toolcrib…before amazon took over -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2737 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
