Is this a good approach to walnut/maple lamination?
Forum topic by BinghamtonEd posted 10-22-2012 07:42 PM 1284 views 0 times favorited 11 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2368 days
10-22-2012 07:42 PM
My upcoming project is going to be a baby gate for our house. To give a interesting look, I decided I would like to sandwich a thin layer of maple in between two thicker layers of walnut, to give it a nice highlight around the edges. The other alternative is to do an all-walnut construction, and then cut a groove down the middle of the pieces and inlay smaller pieces of maple. All joints are going to be M&T.
Which way will be more stable? The last thing I want is for this gate to warp. I could :
- Laminate 4/4 pieces of walnut to get to my final width, then cut the groove and inlay the maple
- Laminate 4/4 pieces of walnut with a 1/4 piece of maple in between
- Use 8/4 walnut and cut the groove and inlay the maple.
For clarification, here is a horrible MS paint sketch, showing the front and side view (side view shows maple).
11 replies so far
BinghamtonEd
#1 posted 10-23-2012 07:15 PM
Anybody?
View chrisstef's profile
chrisstef
17386 posts in 3005 days
#2 posted 10-23-2012 07:19 PM
I would just give it the ole glue sandwich. I dont see much chance of it warping either way you want to do it and glueing would certainly be the easiest IMO.
View ChrisK's profile
ChrisK
1964 posts in 3080 days
#3 posted 10-23-2012 07:26 PM
The 4/4 to maple to 4/4 glue method will help prevent warping as you will be able to alternate the grain on the walnut.
-- Chris K
BinghamtonEd
#4 posted 10-23-2012 07:29 PM
Thanks for the responses. I’m glad my preferred method of sandwiching 3 layers, with the outer layers alternating, seems to be applicable.
View AandCstyle's profile
AandCstyle
3052 posts in 2256 days
#5 posted 10-23-2012 11:25 PM
Ed, to each his own, but IMO you are going through a lot of work for very little visual return. Have you thought about rotating the spindles 90* so the maple shows? Just my opinion FWIW.
-- Art
View crashn's profile
crashn
528 posts in 2464 days
#6 posted 10-24-2012 12:54 AM
i made a solid walnut baby gate, has not warped in 2 years. As long as your lumber is dry and acclimated, you should be good. I do like the idea of a sandwich for visual appeal.
-- Crashn - the only thing I make more of than sawdust is mistakes
View RussellAP's profile
RussellAP
3104 posts in 2285 days
#7 posted 10-24-2012 12:59 AM
For something that small you don’t have to worry about it. Tight Bond II.
View klassenl's profile
klassenl
185 posts in 2658 days
#8 posted 10-24-2012 03:25 AM
I made a baby gate in similar style but I used spruce (2×6) and had no problems with it going out of square. I don’t think that you will have too much to worry about as long as you have good stock.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
BinghamtonEd
#9 posted 10-24-2012 01:17 PM
Thanks for all of the comments.
Art – Rotating the spindles is a nice idea, for my application I think I will keep them square, and soften the corners of them with a small stopped cove routed along each corner of the spindles. My plan is to make this walnut/maple sandwich for all pieces (the outer frame and spindles). The spindles will be narrower than the outer frame. So long as I plane my final laminations equally on both sides (keeping the maple dead center), I hope to have a visually continuous band of maple that flows through the entire piece.
View lumberjoe's profile
lumberjoe
2899 posts in 2247 days
#10 posted 10-24-2012 02:37 PM
I made a table (almost done) and did the same thing for a shelf on the bottom. My only problem was sanding/finishing. Make sure you get ALL that walnut sawdust off. The nice gleaming white Ash sandwiched between the walnut is noticeably darker than the rest of the ash in the table.
BinghamtonEd
#11 posted 10-24-2012 03:50 PM
My other idea, for cost reasons, is to use poplar instead of walnut. I have some Tran-Tint dye that I could use, however if I do that. I would have to dye the wood before the lamination, and I don’t know if I could put finish on (thinking Danish Oil) without smearing the dye into the maple. Any ideas?
