| Forum topic by Candy Hicks | posted 115 days ago | 380 views | 0 times favorited | 15 replies | ![]() |
115 days ago |
Topic tags/keywords: question spray gun finishing rustic Well we have ran into a problem that we have not seen before. We are working with burled wood and some of these stumps are old, very old, they were standing when we cut them and have slabbed them into table tops. Anyway there are a few places of rot, the coloring is all uniform but the wood is spongier and softer than the rest. When we spray Polyurethane or polycrylic on the tops, these spongy spots are absorbing the finish and they look real dull when it is dry. Can a person add a clear wood sealer or primer to this so that it does not absorb so bad? If so do you know of a good brand? I know tha minwax has a few wood sealers but i am not sure if they are what we are looking for. Any information would be appreciated. Thanks and have a superb weekend -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
what are using under your poly coat? i use tung oil first and then put a poly over it, works pretty well up here in the mountains. -- Roper - master of sawdust- |
115 days ago |
we arent using anything under the poly -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
With the punky wood, perhaps a two part epoxy sealer coat. Sean Clarke, a professional finisher and frequent FWW contributor uses “Smith & Company’s MultiWoodPrime (also called Clear Penetrating Epoxy Sealer)” as a first step for outdoor projects. I would think that this might not sink in so quick and would reinforce the structural integrity of the punky wood. I’ve never done this myself, but I know Bob2 uses epoxy to reinforce punky wood during bowl turning and I’m just “thinking aloud” about your problem. -- "Bordnerizing" perfectly good lumber for over a decade. |
115 days ago |
another problem that we have had with the punky wood is with inlaying. We usually take out the worst of the punky wood and fill with inlay, but there is a always some punky wood left. Anyway, when we are sandind down the stones the dust gets into the punky wood and discolors it. Should we try adding the sealer to the wood first before we inlay adn can you resand the sealer so that you get an even finish? -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
Great suggestion Douglas. I have used CA to help seal punky wood on bowls as well. I think if you applied it prior to inlaying it would help stabilize it and minimize dust absorption while sanding. -- My favorite piece is my last one, my best piece is my next one. |
115 days ago |
We do use the CA glue, but it seems to darken the wood and leave it looking wet. -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
I recently milled up some macnut that had been poisoned, I tried Minwax wood hardener and it worked well in the punky areas….although I did coat the entire surface to prevent uneven coloration, the product soaked in well and was dry in about 2 hours, I kept applying it until I had a consistent sheen across the entire surface….smells nasty -- If knowledge is not shared, it is forgotten. |
115 days ago |
I might of just had an Aha moment. I was just thinking that maybe a real simple fix is to use masking tape and place over the punky areas while we are sanding down the stone, I think this would eliminate most of the dust getting stuck…. what do you think? -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
Hi Cindy: I do rustic furniture from tree stumps and old wood, especially wormy wood. It does help with the blochy problem. You’ll need to experiment. -- Randy (P), rustic wood crafts, Morning View, Kentucky |
115 days ago |
Thanks for the information this will truly be helpful, especially since it looks like we might have a few interested retailers. Now if we can get the bugs worked out then all should be good. Thanks again -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
115 days ago |
candy in spongy wood i use white glue watered down.and put 3 or 4 coats on. it fills in the wood. if you put it on light and let it dry good between coats. it seems to not darken the wood as bad. hope this helps. -- hap, gunbarrel city tx. |
115 days ago |
are you using anything as a sanding sealer? Why can’t you blow out the dust after sanding with an air nozzle? -- ~ Inspiring those who inspire me ~ |
115 days ago |
Cyanoacrylate (Crazy glue) is the stuff to use on the spongy spots. Saw David Marks use it to repair a spongy spot in a piece he was working on. -- There are three kinds of people... those who can count, and those who can't |
115 days ago |
I’m working on a project now where I wanted to preserve the rotted edges on some aromatic cedar. Lee -- No piece is cut too short. It was meant for a smaller project. |
115 days ago |
First off I want to thank you for all of the ideas and help, we are going to experiment with many of these ideas and see what works best for us. We ar not using anything as sanding sealer, never even thought about it. ONe of the reasons why we are having a hard time getting the dust out is when we are getting ready to inaly, we cover the edges that are surrounding the area we are going to inlay, with wax. The wax keeps the CA glue from discoloring and soaking into the wood. So if we get wax on the spongy part of the wood, then the dust gets pushed into the wax which gets pushed in to the wood and it wont blow out…. I though about shaping a piece of wax into sort of a pencil with a shap tip so we can better control where the wax goes and also placing tape over the spongy spots. I am sure it is an easy fix, we just need to find a method that works. Thanks again!!! -- Tim & Candy Hicks Custom Log Furniture www.rockymountain-twist.com Dust... What Dust |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
379 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
