final coat over varnish
Forum topic by Steelpapa posted 10-21-2012 10:52 PM 1377 views 0 times favorited 7 replies Add to Favorites Watch
View Steelpapa's profile
Steelpapa
29 posts in 3286 days
10-21-2012 10:52 PM
Topic tags/keywords: varnish final coat
I put 2 semi-gloss coats of Spar Varnish with a brush on walnut.I had little dibs on the finish so I rubbed with 0000 steel wool. It dulled the finish. Any suggestions on what I should of used to keep the shine. Thank You
-- Ron,Texas,http://rjnwood99@clearwire.net
7 replies so far
View upinflames's profile
upinflames
217 posts in 2402 days
#1 posted 10-21-2012 11:58 PM
You can always buff it down with a little paste wax,should bring the sheen back.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4367 days
#2 posted 10-22-2012 12:16 AM
Which brand of Spar Varnish?
Blessings.
-- 温故知新
Gerald Thompson
1142 posts in 2474 days
#3 posted 10-22-2012 12:32 AM
Spar varnish is a poor canidate for rubbing out. It is a long oil varnish that never dries. If it is for an outside piece I would use Epiphanes(sp). They recommend 6 coats.
I tried SV on furniture once and found out there are a lot better choises. Try Waterlox. Go to their site and read all about it.
-- Jerry
View Clint Searl's profile
Clint Searl
1533 posts in 2601 days
#4 posted 10-22-2012 12:35 AM
Spar varnish is a notoriously soft finish. You may be able to restore the sheen by polishing with an automotive polishing compound. Make sure the finish is well cured, first.
If the project is for indoor use, a more appropriate finish would be one intended for same.
Steelpapa
#5 posted 10-22-2012 01:36 AM
Thanks everyone ,the brand is from Lowes….Cabot.Its for a hidden drawer in a blanket-chest.
View Earlextech's profile
Earlextech
1162 posts in 2930 days
#6 posted 10-22-2012 01:40 PM
Spar Varnish is an excellent choice for outdoor finishing, never for indoor. The Deft lacquer next to it on the shelf at BigBoxBlue would have been better. Or shellac. Or poly. Or just paste wax.
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#7 posted 10-22-2012 01:46 PM
I never just leave the final coat ‘as – is.’ I rub it down with 0000 steel wool and apply paste wax. Just rub your hand over it and feel how much nicer it is than straight finish.
