Idea for a circle jig
Forum topic by mIps posted 10-21-2012 09:52 PM 2381 views 0 times favorited 12 replies Add to Favorites Watch
View mIps's profile
mIps
188 posts in 1962 days
10-21-2012 09:52 PM
Topic tags/keywords: jig question router
Okay, on this one I’m looking for a sanity check, so here goes. I am wanting to make a circle jig for my router in anticipation of making some discs for other things (EVIL LAUGH). However, in at least one case, the discs I will need to make will be SMALLER than the diameter of the router base.
So, my thought was to make a circle jig with a indexer with a vaguely + shaped cross-section but a roughly “L” shaped profile so that the center pin can go under the router base, allowing for the smaller circles.
Does this seem plausible or will it all end in ruin?
-- Be honest, honorable, kind, work hard, and generally be awesome.
12 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2269 days
#1 posted 10-21-2012 10:01 PM
Try it and see.
View peterbb's profile
peterbb
37 posts in 2195 days
#2 posted 10-21-2012 10:41 PM
Here’s a couple of pictures of my circle jig – it will do circles from tiny to huge.
The pivot is a #4-40 screw in one end of the slider (barely visible in these picturees). The slider can be installed either way around, depending on the size of circle you want to cut. If you plan ahead, you can make the ranges of the various T-bolt positions overlap.
-- Peter
View mIps's profile
mIps
#3 posted 10-21-2012 11:19 PM
- Peter: How is your base built? That looks like it might be just the ticket.
View jap's profile
jap
1251 posts in 1962 days
#4 posted 10-22-2012 12:28 AM
this jig looks good http://www.leevalley.com/en/wood/page.aspx?p=40970&cat=1,43000 or you could build something simeler
-- Joel
View NiteWalker's profile
NiteWalker
2736 posts in 2485 days
#5 posted 10-22-2012 03:58 AM
mIps, here's the plans. Scroll down a bit for it.
It’s a great design.
View denversigmon's profile
denversigmon
5 posts in 1951 days
#6 posted 10-22-2012 04:10 AM
i am not understating what the work do wood machine
-- Denver Sigmon
116906 posts in 3485 days
#7 posted 10-22-2012 04:16 AM
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3066 days
#8 posted 10-22-2012 04:41 AM
Here’s my circle jig I recently made for my DeWalt trim router. The principal is the same as Peter’s version, allowing the pivot pin to be underneath the router itself. The single 1/4” hole in this image holds a 1/4” pin.
Here is the top side, with the adjustment bolts…
This is a prototype version for me. I will be making something similar out of thick acrylic with an adjustment push/pull pin for fine tuning the circle radius.
-- jay, www.allaboutastro.com
peterbb
#9 posted 10-22-2012 05:03 PM
The base of my jig is 1/2” plywood with a dado to suit the slider, and a slot for the T-bolt. The slider is about 3/4 wide by 3/16 thick, and as long as desired. It was likely inspired by the plans posted by NiteWalker (don’t recall the actual source…)
The jig shown by Comicsniper looks excessively thick to me – I don’t think I could cut through 3/4” material with it.
-- Peter
Cosmicsniper
#10 posted 10-22-2012 05:32 PM
Peter. Yeah, mine bottoms out around 3/4”, but mine isn’t designed to be used on thick stock. 1/4” plywood would be completely satisfactory and would have the same depth as your jig.
View Sylvain's profile
Sylvain
688 posts in 2407 days
#11 posted 10-23-2012 12:39 PM
Jig for very small circle (0” [inside] up to about 11”)
added bonus : no pin hole
http://www.lescopeaux.asso.fr/Techniques/Docs/Sante_Tripode_Anglais.pdf
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View dclark1943's profile
dclark1943
268 posts in 2095 days
#12 posted 07-12-2013 02:28 PM
Sylvain, Just what I need, I am building a wedding box, and need two overlapping circles to represent the wedding bands. can’t have a center hole, and need to cut contrasting wooden circles to inlay into the routed circles.
-- Dave, Kansas City
