Grizzly G1023RLW or G1023RL / T10222 Router Extension Table
Forum topic by ChaseD posted 10-21-2012 05:48 PM 5581 views 0 times favorited 13 replies Add to Favorites Watch
View ChaseD's profile
ChaseD
2 posts in 2225 days
10-21-2012 05:48 PM
Topic tags/keywords: grizzly 1023 1023rl 1023rlw table saw
Hello Folks!
Great site with tons of useful info!
Looking at ordering the Grizzly G1023, just wondering if I should get the RLW with the built in router table or get the RL and the T10222 Router Extension Table?
I currently have a smaller shop and a dedicated router table does not fit the plan, I do use my router a fair bit and wondering what would be best. Will the built in table suffice or should i get the more versatile extension table?
I am coming from a dewalt dw745 contractors saw and my projects have out grown the saw, time to upgrade!
Thanks
13 replies so far
View jblavigne's profile
jblavigne
3 posts in 1872 days
#1 posted 10-17-2013 06:21 AM
I’m wrestling with the same question right now – what did you end up doing?
-- "Then the Lord God formed the man from the dust of the ground. He breathed the breath of life into the man's nostrils, and the man became a living person."
View knotscott's profile
knotscott
8141 posts in 3554 days
#2 posted 10-17-2013 10:14 AM
A router table built into the wing of a table saw is a excellent space saving compromise IMO. A stand alone certainly has the lion’s share of advantages, but putting it on the TS wing is a viable option that saves space. There are plenty of fence, storage, and DC options that can be implemented. I’ve had one on my saw for better than 10 years and have built a few versions. The RLW offers quite a bit of router table for a small premium IMO.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3092 days
#3 posted 10-17-2013 11:13 AM
GET THE T10222 EXTENSION!
I had had one on my G0690 since day one and love it! I also reused the right OEM wing, but had to drill the three outer mounting holes on the OEM wing to fit the T10222 and buy the bolts. Notice that it matches the length of the OEM rails perfectly.
View Oosik's profile
Oosik
126 posts in 1861 days
#4 posted 10-18-2013 03:32 AM
Mike is the rolling base extension a separate piece from the saw base?
That is a setup I have envisioned once the funds come together.
View darthford's profile
darthford
612 posts in 2102 days
#5 posted 10-18-2013 04:02 AM
Oosik yes rolling base extension is a separate piece http://www.grizzly.com/products/Extension-Kit-For-D2057A/D2259A
Mike that’s a great setup I love all that cast iron!
darthford
#6 posted 10-18-2013 04:10 AM
Hey Mike how do you like those yellow board buddies? I have a set arriving tomorrow.
jblavigne
#7 posted 10-18-2013 04:49 AM
Does anyone know if/how the t10222 fits the OEM rails on the g1023rl?
HorizontalMike
#8 posted 10-21-2013 03:51 PM
Opps, missed the thread for a couple days…
YES, the mobile base “Extension” is extra: http://www.grizzly.com/products/Extension-Kit-For-D2057A/D2259A
Just the mobile base: http://www.grizzly.com/products/Heavy-Duty-Mobile-Base/D2057A
YELLOW BOARD BUDDIES—I love them! IMO, more durable than featherboards, and since the wheels are synthetic rubbler they do not mar your lumber. Don’t forget to order the 24in mounting rail (the longer one) for the board buddies, as well. It makes changing locations and adjustments much easier:
http://www.grizzly.com/products/W1108
Oosik
#9 posted 10-22-2013 06:34 PM
Mike,
Can you post pictures on how you kept the right wing and added the router table?
I might bite the bullet and get a grizzly new and attempt the same setup you have.
How hard was it?
How do you like the shopfox base too? Amazon reviews don’t shine a pretty light and people recommend a rockler base but there is no extension for the table legs.
HorizontalMike
#10 posted 10-22-2013 10:21 PM
No pictures… You just have to line up the router wing to the outside of the mounted right table wing, mark the holes with a pencil and drill the appropriate sized holes. Not rocket science, but yes… a bit tedious to get it right. Don’t forget the tape trick if the wing sags or is high…
If the holes are slightly large, that is not a problem. You semi-snug the bolts and then “tap” the wing flush before tightening the bolts.
Oosik
#11 posted 10-22-2013 10:49 PM
Tape trick?
How do you like the portable base, any problems with it?
HorizontalMike
#12 posted 10-22-2013 11:44 PM
If sagging = tape strip on bottom half of wing THEN TIGHTEN
If rising = tape strip along top strip of wing
RE: the mobile base… I love it! Allows me to move anywhere I need it to be. Easy to level/flatten wings as needed.
darthford
#13 posted 10-23-2013 02:39 AM
Drill press helper for installing these heavy cast iron tables
