Need tips for making box joints
Forum topic by DaveFFMedic posted 216 days ago 1515 views 2 times favorited 34 replies Add to Favorites Watch
View DaveFFMedic's profile
DaveFFMedic
67 posts in 339 days
216 days ago
Topic tags/keywords: jig question box joinery
Recently I posted a project for a wooden beer holder for six bottles. Last night my brother in law asked if I could make six of them for his reenacting group.
I would like to make the holder using box joints, but I have never had luck making box joints. Particularly small box joints. I made my own box joint jig which is functionally similar to the Rockler jig and It just doesn’t seem to give me the accuracy I am looking for.
My options are a table saw with 1/8” ATB blade, dado blade, or router table with 1/4” spiral bit. I can buy more router bits or make another jig. I’m looking for some advice. My box joints never seem to mesh. They are always off by just enough that they mesh at one end, but don’t line up at the other end.
Thanks for your help!
Dave.
34 replies so far
View NiteWalker's profile
NiteWalker
1483 posts in 749 days
#1 posted 216 days ago
Buy once, cry once.
Mine shows up monday.
Here’s a couple of videos:
Incra product video
Review by Tom Hintz
View Cosmicsniper's profile
Cosmicsniper
2150 posts in 1331 days
#2 posted 216 days ago
A homemade sled should work pretty well. You just have to be patient while dialing in your key size.
That said, I now use my Incra router setup.
-- jay, www.allaboutastro.com
View teejk's profile
teejk
972 posts in 857 days
#3 posted 216 days ago
I think the key to a home-made jig is that the alignment finger is exactly the width of your dado and spaced exactly away from the dado. and then the dado set needs to be at a perfect 90 to the table and close to the proper height (err on a little taller…you can always sand off the excess tails). And then a backer board is essential. there are a lot of “exactlys” there but it does make a nice looking joint.! This came from an old cherry beam (wormholes and all).
http://i1217.photobucket.com/albums/dd385/Teejk/0911021016.jpg!
View Gene Howe's profile
Gene Howe
3200 posts in 1601 days
#4 posted 216 days ago
I use 1/4, 3/8 and 1/2 jigs like this. Box Jig Except mine is made of polypropylene instead of laminate covered MDF.
MLCS has an excellent video on it’s use. VIDEO#!
Easily adjusted for great fitting joints.
DaveFFMedic
#5 posted 216 days ago
It seems like the Incra jig is a favorite here. I don’t think its in my budget right now. If I understand right, it’s not so much the jig, but my patience to dial it in. Does anyone have any tips or tricks to getting the spacing just right?
View waho6o9's profile
waho6o9
2933 posts in 749 days
#6 posted 216 days ago
Cosmicsniper
#7 posted 216 days ago
Yep, for most homemade jigs, I’d start with the key-size. I like something with a set width, like metal rods with precisely the right diameters. From there, you adjust your dado set (make sure its a stacked dado set) with the appropriate shims to give you the right width to match your key. Then, make one cut at that width and then you can fit your key. Use a second, identical key as a spacer to set the correct distance for the next cut. Once you’ve done this correctly, everything else falls right in line.
I originally made a 1/2” one with a wooden key. I made the 1/4” version with a drill shank (which is just a tad less than a true 1/4”). But that didn’t matter much to me since I just adjusted the dado stack to match. I usually adjusted the project dimensions to match the overall number of fingers, so that I didn’t have anything end in the middle of a finger.
teejk
#8 posted 216 days ago
cosmic…I think the “key” slot has to be made at the same time as the rest of the jig…variations in the dado set (a tooth here and tooth there can goof it up). I followed the “nail-gun Norm” plan for the jig (a lot of people don’t like him but he taught me a lot) but I built mine so long ago that I forgot the process and they work so well that I haven’t seen the need to do it again!
I’ll get some pix…it’s pretty easy I think (a very sharp pencil and a good tape measure). As I recall though it was a pass with the dado set, then a measurement from the edge of one cut leaving exactly that distance of “meat” before the next cut without changing the dado set or depth. The alignment “key” (milled from a scrap of hardwood) goes on the right side slot in my case.
View RogerM's profile
RogerM
316 posts in 572 days
#9 posted 216 days ago
You can get accurate box joints almost every time using the Woodsmith Box Joint Jig which is available at Rockler. Probably like yourself, I made at least two complete jigs for cutting box joints but ended up with the Woodsmith box joint jig after many failures and unsatisfactory results. Go ahead and lay down $120 and eliminate the frustrations.
-- Roger M, Aiken, SC
TopamaxSurvivor
13194 posts in 1848 days
#10 posted 216 days ago
A simple sled jig for a single size is eay to make.
View gfadvm's profile
gfadvm
6660 posts in 863 days
#11 posted 215 days ago
I use shop made box joint jigs attached to my cheapo miter gauge with shop made “T track”. This allows for very easy and quick tweaking when setting it up. I also highly recommend the Freud Box Joint cutter blades as they cut perfectly flat bottoms and the cuts are always EXACTLY 1/4” or 3/8” wide. Another important factor is NO slop in your miter slot fit when using the miter gauge (I tightened mine with a center punch). I posted my simple jigs in my projects if you are interested. Once you get the technique down, you will cut perfect fitting box joints every time with these blades and a shop made jig.
View ajosephg's profile
ajosephg
1723 posts in 1733 days
#12 posted 215 days ago
If you are going to make hundreds, I still think the best way is to use a dovetail jig with a box joint template such as a PC 4212
-- Joe
NiteWalker
#13 posted 215 days ago
What advantages does the 4212 have over the ibox?
I have the 4212 and decided on the ibox for box joints because the setup and adjustability is much easier. Cutting time is probably about the same, but with the ibox there’s less chance for tearout.
View sikrap's profile
sikrap
796 posts in 1531 days
#14 posted 215 days ago
I made the jig that was in ShopNotes a while back and I wasn’t happy with it. I bought the ibox and was making boxes within 30 minutes of opening the box. Yes, its more money, but it can’t be beat for simplicity and ease of use.
-- Dave, Colonie, NY
NiteWalker
#15 posted 215 days ago
That’s the main reason I grabbed it too Dave.
showing 1 through 15 of 34 replies
