old stain
Forum topic by Richard posted 10-21-2012 01:25 AM 810 views 0 times favorited 3 replies Add to Favorites Watch
View Richard's profile
113 posts in 3349 days
10-21-2012 01:25 AM
Topic tags/keywords: finishing
I have some old stain I am trying to match. i opened the container(not a traditional brand with lables) up and all that was left was some chunks of solid stain. I think it is oil based. Can I put a chunk of it in something to make it usable so I can get a better match? Thanks For any ideas.
3 replies so far
View huff's profile
2828 posts in 3218 days
#1 posted 10-21-2012 12:24 PM
If it was an oil based stain, then you may be able to take a little mineral spirits and desolve the solid enough to get it so you could at least put some on a sample board to work with.
All your pigmented stains will use some sort of “vehicle” to suspend the pigments in to allow you to work with it and the “vehicle” will dry or evaporate when you apply your stain. Usually mineral spirits will work as a “vehicle”.
Just remember, the more mineral spirits you mix with the pigments, the more it will be deluted which in turn will change the density of color.
-- John @
View Monte Pittman's profile
Monte Pittman
28592 posts in 2271 days
#2 posted 10-21-2012 01:03 PM
John’s suggestion is probably the best. Try not to over thin it and give it time to dissolve.
-- Mother Nature created it, I just assemble it.
#3 posted 10-21-2012 01:25 PM
Thanks for the advice. I left a chunk of it in some mineral spirits overnight and nothing happened. I think it was a custom mix by the cabinet maker. When I opened the jar up it stunk to high heaven. I will just have to do it by trial and error on scrap wood. Thanks again.
