air hose decinagrates, how to prevent next time
Forum topic by JesseTutt posted 10-19-2012 05:36 PM 1925 views 0 times favorited 18 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2110 days
10-19-2012 05:36 PM
Topic tags/keywords: question air hose air compressor
I have a small Harbor Freight air compressor that I occasionally use to add air to a tire or power a nail gun. The air compressor, regulator, hoses, etc probably have seen less than 3 hours use since I installed the system about 4 years ago.
Recently, I needed to use my 23 gauge pin nailer and so I fired up the air compressor. There was a constant hissing of escaping air. It turned out to be from a bad air line connecting the air compressor to the regulator. The rubber is completely shot next to one connector, and is hard over the entire 3’ length.
I have since replaced it with a slightly longer hose. But, I am wondering what maintenance I should be doing to keep the hose from degrading in the future?
Here are a couple of pictures:
The black spots on the plywood is rubber flaking off of the hose
18 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3561 days
#1 posted 10-19-2012 06:00 PM
I have never seen a hose decompose like that in 4 years, so I’d attribute it to bad quality/materials. Hopefully your new one is of higher quality. I don’t know of any maintenance that needs to be done other than keeping it out of solvents and liquids in general. Oh, and avoid kinking it especially near the fittings.
-- Joe
View NiteWalker's profile
NiteWalker
2737 posts in 2577 days
#2 posted 10-19-2012 06:01 PM
Get a better hose. Legacy’s flexzilla hoses are amazing.
View teejk's profile
teejk
1215 posts in 2684 days
#3 posted 10-19-2012 06:20 PM
exposed to sunlight?
View DKV's profile
DKV
3940 posts in 2504 days
#4 posted 10-19-2012 06:21 PM
Do we no longer have any pride in our spelling? Jesus loves you anyway.
-- This is a Troll Free zone.
View crank49's profile
crank49
4030 posts in 2971 days
#5 posted 10-19-2012 06:24 PM
Most of those small compressors have a rubber hose connected to the pump output and going to the tank or a regulator.
I have a Porter Cable made the same way.
I have been expecting it to do just what yours has done because of the heat.
Thankyou for confirming my suspicions.
A reasonable fix would be to replace that section of hose with copper tubing; preferably with a loop to allow enough flexibility.
JesseTutt
#6 posted 10-19-2012 06:58 PM
I was thinking of how people rub something on their dashboards and tires.
Teejk: no not exposed to sunlight
DKV: try typing on an e-book reader keyboard. Also, I don’t see anything about this topic what would imply that I am not acting like an adult.
Crank49: the compressor did not come with a regulator or hose. I added both of them from Harbor Freight. I went with a rubber hose so that I could move the compressor.
NiteWalker: I replaced it with a piece of Goodyear rubber hose. I hope that has a better life expectancy.
View Dave G's profile
Dave G
332 posts in 2048 days
#7 posted 10-19-2012 09:49 PM
Hi. If it’s too near an electric motor like a furnace pump or blower it will degrade rapidly. Also, spraying with silicone spray or Armorall will increase it’s life.
-- Dave, New England - “We are made to persist. that's how we find out who we are.” ― Tobias Wolff
teejk
#8 posted 10-19-2012 09:51 PM
dkv…I checked the spelling bee finals for the past several years and I didn’t see your name. I would guess that most people on this site are looking for help or are trying to help others and spelling/punctuation goes unnoticed (as they should).
teejk
#9 posted 10-19-2012 09:58 PM
Dave G…I remember the “ozone” thing from electric motors but I have had one of those wheel barrow compressors where the hose is always near the motor (30 some years now) and the hose is just fine (wish I could say the same for the tank).
The little pancakes regardless of brand come with a rather hard vinyl coating. Junk I think…replace with quality hose and good to go. Do remember to drain the tank though!
117091 posts in 3577 days
#10 posted 10-19-2012 10:05 PM
Given that it comes from HF it’s possible the hose is made from natural rubber , making it much more susceptible to
deterioration.
Dave G
#11 posted 10-19-2012 10:23 PM
teejk – yes bit of a puzzle since modern times I haven’t seen rapid deterioration. Probably Jim’s hit the nail.
View dhazelton's profile
dhazelton
2767 posts in 2296 days
#12 posted 10-19-2012 10:26 PM
Nothing you did, hose quality I assume. ALTHOUGH someone once said that if you kept anything rubber in a garage with a fridge or freezer that it would deteriorate more quickly due to off gassing from the compressor. I didn’t think a closed system like that would off gas, but your mileage may vary.
View Grandpa's profile
Grandpa
3259 posts in 2675 days
#13 posted 10-20-2012 01:43 AM
Interesting that it is worse in the one section near the end.
View juniorjock's profile
juniorjock
1930 posts in 3765 days
#14 posted 10-20-2012 02:15 AM
DKV – - – - What the hell is wrong with the spelling? I saw a couple of typos in the OP, but nothing I thought needed pointed out. Something I’m missing? Or are you perfect….........?
View DKV's profile
DKV
#15 posted 10-20-2012 02:17 AM
Junior… decinagrates???
Yes junior I am as near perfect as possible. Look at my avatar…
