Advice on finishing black walnut
Forum topic by RussellAP posted 217 days ago 1389 views 0 times favorited 24 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 458 days
217 days ago
Here’s the scoop. I’m going to build a 7’x3’x14” book case out of black walnut 5/4 stock I get from a local guy who has a mill and a kiln.
I’m working on the finish before I start the piece because as we all know, finishing is 90% of the job.
I’m trying to get the most professional look as I can on this walnut.
I’ve been investing in Danish oil and have taken a piece of the walnut and sanded it to 320 and used Golden Oad, Red Mahogany, and natural danish oil on it and have decided that I like the Golden Oak tone best, and the natural second best.
My problem is that some parts of the wood look like they’ve blotched.
Should I use Charles Niel’s pre color conditioner on them?
What do you think.
Bear in mind, I’m going with the danish oil and not anything else except wax after it’s done, so don’t recomend some esoteric brand of stain or whatever, I’ll try that next time. My mind is made up that Danish oil makes for a finish that appeals to me.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
24 replies so far
View rance's profile
rance
3856 posts in 1332 days
#1 posted 217 days ago
Personally, I use ’Natural’ Danish Oil one on Black Walnut all the time(most recently in class just last night). It looks very professional. I also have an aversion to coloring wood, although I do it from time to time, but mainly with bright transtint dyes. I use Watco.
View Rick M.'s profile
Rick M.
1504 posts in 551 days
#2 posted 217 days ago
Golden oak on walnut, I’m curious what it looks like. Can you post a picture?
I haven’t tried a tinted oil on walnut but I have stained sapwood without problem. If you’re getting blotching then a conditioner would be the ticket.
-- -- Rick M.
RussellAP
#3 posted 217 days ago
Wormil, I don’t think a picture would capture the subtle difference. In walnut there is a confluence of medium to dark browns in the wood. The golden oak lightens up the lightest browns but doesn’t really do anything to the darker. It increases the parameters of the color spectrum. The red does the same only a slight red tint remains and the board is generally darker. The natural works for me too, but I need to keep it from blotching. I didn’t think Walnut blotched.
rance
#4 posted 217 days ago
BTW, for the class, I often just sand up to 150 and quit. Sometimes to 180, rarely to 220. I NEVER go past 220. I’ve never had blotching on Walnut.
Rick M.
#5 posted 217 days ago
Good point, I’ve never sanded walnut past 220 either. Could be the extra sanding is impeding absorption of the oil.
-- -- Rick M.
View Monte Pittman's profile
Monte Pittman
7074 posts in 509 days
#6 posted 217 days ago
I don’t have near the experience with this kind of wood, but I would nearly always vote for natural
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1330 days
#7 posted 217 days ago
Ditto, Rance. Never blotched walnut and I always use natural color on black walnut…though not a big deal using something different.
Bookcases can get beat up a bit. You sure you don’t want something over the Watco? It’s really not that much protection from scratches.
Are you sure the blotchiness you are seeing isn’t just some chatoyance? That’s my favorite aspect of that wood. If it is blotching, then yes, use some pre-conditioner or seat-coat shellac…I’d just be careful with the amount, else the oil can’t do its job.
-- jay, www.allaboutastro.com
Cosmicsniper
#8 posted 217 days ago
If you’ve sanded to 320, that would keep it from absorbing and, therefore, prevent blotching. Though perhaps its just that some areas are not absorbing at all.
I’d use a scraper instead of an abrasive….or at least as a final go-over. Bookcases are easy in that way.
RussellAP
#9 posted 217 days ago
Here are a few examples of the blotching.
View jusfine's profile
jusfine
2157 posts in 1097 days
#10 posted 217 days ago
Nice figured walnut, the photo doesn’t show the blotching like I thought it might, I can’t really see it clearly.
I have never tried anything else other than a clear coat on walnut, but the photos do make the color look good.
All the best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Cosmicsniper
#11 posted 217 days ago
Not seeing the blotching either. That 3rd picture looks like chatoyance to me. Lightly sand that back with 150 to 180 (or better yet scrape it) and apply more of the Watco. See what happens.
RussellAP
#12 posted 217 days ago
Cosmic, I don’t think he planes them. I have a planer that I need to set up and I plan to plane and joint every board, so maybe that will make the difference. I just sanded the kerf marks out of it without anything else.
Cosmicsniper
#13 posted 217 days ago
Oh, I’d bet that’s the issue.
Sandpaper is one of those things I am learning to do without. I use my hand planes and scraper for the majority of my prep work now. I save the sand paper for plywood and finish work (between coats). I’ll also use it on end grain if I worry about too much absorption.
I’d do some test boards after running them down with a good No. 4 plane or a scraper.
RussellAP
#14 posted 217 days ago
I wonder if I wait for the oil to cure if that blotch will go away.
Cosmicsniper
#15 posted 217 days ago
It won’t.
If you have more testing wood, try applying the same finish to differently prepped boards. It’ll be very instructional.
