ZCI's
Forum topic by MrRon posted 10-18-2012 10:17 PM 1345 views 0 times favorited 13 replies Add to Favorites Watch
View MrRon's profile
MrRon
4710 posts in 3207 days
10-18-2012 10:17 PM
Please forgive me in advance for my comments. ZCI or zero clearance insert has been on the lips of woodworkers for a couple of years now. Not too much has been said about them other than they can reduce splintering. Many have posted how to make ZCI’s, but now pop-up ads are advertising ZCI’s for $95. You have to be out of your mind to spend $95 on a piece of aluminum plate and a wood insert. They even have the gall to sell replacement wood inserts for the ZCI. This is really taking advantage of the public. There are those who would defend it by saying “I don’t have the time to make one”, or “money is no object”. I don’t think they represent the majority, but if they do, then I’m in the wrong business. Any halfway proficient wood hacker could make one in 15 minutes. To borrow a quote from Geico; “Even a Caveman could do it”. I usually don’t bother with ZCI’s anymore because the “wobble” of saw blades destroy the zero clearance very quickly. The companies that sell these ZCI’s are out to get your dollar regardless of it’s advantages. I would rather see them pushing a saw blade that promises a fine cut at an affordable price.
13 replies so far
HillbillyShooter
5811 posts in 2256 days
#1 posted 10-18-2012 10:30 PM
Tend to agree on ZCIs, although I have no complaint about problems with blade wobble. I made 8 or so ZCIs back in 1994 and still haven’t used half of them. My experience has been that a good blade (Systematic or Forrest) eliminates the need for a ZCI except in very limited circumstances.
View ajosephg's profile
ajosephg
1880 posts in 3524 days
#2 posted 10-18-2012 10:43 PM
I agree with everything you said, Ron, except “the “wobble” of saw blades destroy the zero clearance very quickly.
I’ve been using the same ZCI for years and it will last indefinitely. I use it with three different Freud blades, crosscut, rip, and combination.
Besides the better cut a ZCI provides, there is also a safety factor when cutting small pieces. The ZCI prevents the cutoff from getting jammed between the blade and the insert resulting bad consequences.
-- Joe
View NiteWalker's profile
NiteWalker
2736 posts in 2540 days
#3 posted 10-18-2012 11:02 PM
Ron, if you’re having trouble with blade wobble there’s a setup issue with your saw or excessive runout somewhere. I agree about the aluminum insert style ZCI’s. I realize they cost money to design and produce, but $95 is really pushing it. A phenolic leecraft insert for $20 and an afternoon and you can have the same thing. There’s plans out there that show you how to do so.
Unless I’m beveling, a zci is a must on my tablesaw, regardless of blade quality. The best blade in the world won’t prevent a narrow offcut from falling in the slot and causing all kinds of problems.
Gerald Thompson
914 posts in 2198 days
#4 posted 10-18-2012 11:24 PM
The only thing I disagree with is “This is really taking advantage of the public.” If a person wants one and buys it I do not believe he is being used. It is one’s responsiblity to find out what products suit one’s tastes and pocket book.
There is no way I would be in the market for that product.
-- Jerry
View Richard's profile
Richard
400 posts in 2655 days
#5 posted 10-19-2012 03:50 PM
I don’t know where you are shopping for ZCI’s but I just bought one for my TS at Woodcraft for under $30.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
View wunderaa's profile
wunderaa
248 posts in 2166 days
#6 posted 10-19-2012 04:07 PM
Can’t say I agree with the sentiment toward the company “taking advantage of the public”. If there is a market for $95 ZCI’s, then more power to them for supplying the demand. If there’s not a market for them, then you won’t see them around for long.
As for side-stepping the use of a ZCI, I would caution against it. It takes the right conditions for things to go horribly wrong at the TS, so it’s best to eliminate the easy stuff like blade clearance. Even a worn out ZCI is better than utilizing a stock insert with a 1/2” gap.
My $0.02…
View knotscott's profile
knotscott
7980 posts in 3339 days
#7 posted 10-19-2012 04:08 PM
I agree that it’s silly for a hobbyist to pay $95 for a ZCI, but I do want to emphasize how critical it is to a table saw’s precision to have good insert that’s stiff and flush to the table. There’s not a TS on earth that that’ll cut well if the insert is flexing or causes the work piece to shift during a cut. I’ve made several ZCI’s out of various materials, but I really like the Leecraft phenolic inserts that are available in the $20 range….they’re stiff, last a good long time, and I can always make a wood patch if the opening gets sloppy.
View rance's profile
rance
4255 posts in 3124 days
#8 posted 10-19-2012 04:20 PM
+1 to exactly what ajosephg said(thanks for saving me the typing).
+1 to getting your wobble fixed. Your machine just aint rait(spoken in my best Forrest Gump voice).
NiteWalker
#9 posted 10-19-2012 04:33 PM
“I can always make a wood patch if the opening gets sloppy”
That’s the same thing I plan to do.
MrRon
#10 posted 10-19-2012 09:35 PM
The $95 I referred to came as a pop-up on the right side of my screen and wouldn’t go away. By taking advantage, I mean that newcomers to this hobby who know very little might be convinced that a ZCI is a necessity. A year down the road, that same person might come to realize how easy it would be to make one and save the money for something more useful. I must confess that once I bought something and discovered how simple it was and could have made it just as well or better. You end up kicking yourself for not knowing better.
I would also caution others about those hockey pucks they sell as “bench cookies”.
NiteWalker
#11 posted 10-19-2012 10:32 PM
A few things:
1. Adblcok plus and no more ads.
2. Most newcomers don’t jump in blindly; and even less spend $95 on an accessory without doing a bit of research. I just bought an incra ibox and a hingecrafter as well but not before spending the past 48 hours almost non stop reading what I could find on them and watching videos.
3. Bench cookies are a great value. For the time and material investment it’s cheaper overall to buy a set for $11.
For some people, time is worth more than money.
You’re not out of line though; the way you feel about these zci’s is the same way I feel about most things festool…
MrRon
#12 posted 10-19-2012 10:58 PM
That’s where we disagree. Festool tools are of the highest quality, although I can’t afford them. If I had the money, I would have all Festool tools. Bench Cookies are a different story. They are just repurposed hockey pucks. A round of scrap wood with a disc of rubber glued on would be the same. You could even drill a hole in the center for a thread insert and it would only cost you maybe 25¢ each. A fool and his money are soon parted. (a very wise saying from us older guys).
HillbillyShooter
#13 posted 10-20-2012 12:44 PM
Thanks to “ajosephg” and others for pointing out the safety factors in using a ZCI. Frankly, I had not considered this and will start using ZCIs more in the future.
