Rounding Corners with Spare CDs
Forum topic by captfoss posted 10-18-2012 06:26 PM 930 views 0 times favorited 2 replies Add to Favorites Watch
View captfoss's profile
captfoss
20 posts in 2125 days
10-18-2012 06:26 PM
Topic tags/keywords: rounded corners routing template tip trick
I’ve been looking for ideas online about how to accurately cut rounded corners. The standard method of doing that appears to be tracing a coffee can, removing most of the excess wood, and then sanding to the line. Some people do that to create a router template, or to do the actual rounding itself.
That seems like a nice idea, but I don’t have the sanding equipment or skill necessary for it to work especially well. I think an alternate approach to rounding corners could be to grab some spare CDs, and use those directly as your router template.
3 CDs would give you a 1/8” plastic template, and 6 CDs would give you a 1/4” template. Glue them together, and you’ve got yourself a perfect 2.5” radius rounding template. The CDs have the benefit of being sturdy enough to route against, as thin or thick as you need them to be, and they won’t ruin your router bit if you should happen to run your bit into them.
Attach with double-sided tape, and route with your preferred template routing method.
2 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2483 days
#1 posted 10-18-2012 09:15 PM
That will work. :)
View gfadvm's profile
gfadvm
14940 posts in 2596 days
#2 posted 10-19-2012 01:55 AM
Good tip. Thanks. Now figure a neat trick for an inside circle template!
