Spray Shellac Finish
Forum topic by Alongiron posted 219 days ago 647 views 0 times favorited 9 replies Add to Favorites Watch
View Alongiron's profile
Alongiron
333 posts in 866 days
219 days ago
I am a big fan of using shellac on all the Arts and Craft projects that I make. I liked to do it the old fashioned way by using a brush but there are times when it is difficult to do so. Can someone help me to understand what kind of spray gun to use when spraying shellac. Thank you
-- Measure twice and cut once.....
9 replies so far
View pintodeluxe's profile
pintodeluxe
1756 posts in 986 days
#1 posted 219 days ago
I use the Woodriver (Woodcraft) Gravity feed HVLP gun. I have also used Porter Cable’s gravity feed HVLP gun, both with great results. They come with 1.5 mm needle sets, which work great for shellac or lacquer. I really prefer pre-cat lacquer, but the guns spray shellac well too.
View NiteWalker's profile
NiteWalker
1483 posts in 750 days
#2 posted 219 days ago
I use a gravity detail gun with a 1.2mm nozzle setup.
View Paul Miller's profile
Paul Miller
21 posts in 1626 days
#3 posted 219 days ago
One of the HF gems. $15 gets you their 20 oz gravity feed HVLP with 1.5 mm tip. If you need a regulator at the gun, they have the same model with regulator for $35. I’ve been using it for years and never had a problem. I even bought a couple on sale for spares but haven’t needed them yet. If the project is going to take a while to finish, I’ve left shellac in the gun for several days without cleaning it. No clogs, just give it a shake to mix the shellac, and start spraying again.
Paul
View Gary777's profile
Gary777
80 posts in 771 days
#4 posted 93 days ago
I thought I would add a tip I learned the hard way, I always mix my own Shellac from scratch using flakes, since starting to do this my finishes have improved dramatically. It also saves on waste since Shellac has a fairly short shelf life. I usually use a 1lb cut regardless of if I’m spraying or brushing and I just apply more coats.
Another tip, the cut doesn’t matter as much as most people think, a thinner cut will flow smoother and dry faster, you’ll need more coats but each coat will be more consistent. If you think about it the alcohol is going to evaporate anyway, if you are in a hurry and want to use a thick cut and apply less coats you are increasing your odds of runs and other thick finish ills, I used to do this because I was eager to see the fruits of all that hard work, then I learned (the hard way) that sanding and finishing are just as important as craftsmanship of construction.
If you slow down, go thin and add more coats I think you’ll really like the results.
-- Gary - Carson City, NV - "Every man looks upon his wood pile with a sort of affection." — Henry David Thoreau
View MT_Stringer's profile
MT_Stringer
726 posts in 1404 days
#5 posted 93 days ago
+1 – What Paul said.
View stevenmadden's profile
stevenmadden
173 posts in 1262 days
#6 posted 93 days ago
Alongiron: I recently completed an armoire project where the finish was a 1 pound cut blonde dewaxed shellac that was sprayed on; one coat on the entire piece and three coats on the internal components. The outside was then finished with General Finishes Arm-R-Seal oil and urethane topcoat; two coats gloss and one coat semi-gloss. The system I used to spray the shellac was a Binks spray gun with a 1.4mm tip (I think) connected to a pressure pot. I couldn’t have been more pleased with the results. The spay goes on easily, dries quickly, and I think it looks great.
Steven
Alongiron
#7 posted 93 days ago
Thanks for all the great comments and suggestions. Question. Don’t you ger a lot of over spray all over the shop? What kind of protection do you use to protect your work area.?
Gary777
#8 posted 93 days ago
I use an Earlex 5500 HVLP system and open ended tent/booth for spraying using 2mil plastic sheeting, I also use a fan to push air into the tent and exhaust it outside, it’s not optimal (i wish I had room for a dedicated booth) but I don’t spray for hours at a a time ether. I’ve heard people state huge CFM numbers (5400cfm, which is huge for an 8×10 room) for air circulation but that just seemed nuts to me, half of your finish is being swept away with that kind of flow. I use about 300CFM in 6’ x 8’ tent. But make sure the visible over spray mist is being exhausted, if it’s getting behind the fan it could go boom!
The beauty of spraying Shellac is that it’s such a quick process and the clean up is easy and it;s much less dangerous than lacquer. I spray lacquer too but only outside when the weather is nice and it’s not windy.
View Jim Finn's profile
Jim Finn
1069 posts in 1095 days
#9 posted 93 days ago
I have heard that shellac has a short shelf life but I was given some that was years old and it worked well for my needs. What goes wrong with shellac over time?
-- In God We Trust
