Lubricant for wet sanding shellac with micro-mesh
Forum topic by Rickterscale posted 10-18-2012 04:20 PM 2391 views 0 times favorited 3 replies Add to Favorites Watch
View Rickterscale's profile
Rickterscale
162 posts in 2230 days
10-18-2012 04:20 PM
Topic tags/keywords: shellac wet sanding rubbing out micro-mesh
I’ve got a project on which I’m applying a shellac finish. I bought some micro-mesh sanding disks to smooth and buff/rub it out to a gloss finish. In my experience dry sanding shellac always clogs the sand paper, and I don’t want to clog the pricey micro-mesh, so I thought I’d wet sand. But what do you use for the lube? I’ve read that mineral spirits will cause separation of the padded backing from the micro-mesh sanding paper. So what to use? Is soapy water okay to use on shellac? Thanks in advance!
3 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2559 days
#1 posted 10-19-2012 02:25 AM
I sand shellac with Abranet discs all the time with no lube and haven’t had problems with clogging provided the shellac is well cured (dry). I do this by hand, not with a ROS. I usually stop at 600 grit so can’t comment on finer grits.
View DW833's profile
DW833
212 posts in 1751 days
#2 posted 08-21-2014 01:44 AM
Rickterscale, I have the same question on using the micro-mesh. What did you end up using as a lubricant?
View knotheadswoodshed's profile
knotheadswoodshed
211 posts in 2041 days
#3 posted 08-21-2014 01:54 AM
I use Behlens wool lube on my lacquer finishes with the micro mesh and to gfadvm’s point, it needs to be properly cured first.
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
