Bent steel rod
Forum topic by mnorusis posted 213 days ago 688 views 0 times favorited 12 replies Add to Favorites Watch
View mnorusis's profile
mnorusis
153 posts in 1309 days
213 days ago
For my current project, I need to either make or buy a steel rod (probably either 3/8” or 1/2” diameter) with a 90 degree bend in it.
I can find all the straight steel rod I could want online or in local stores.
Does anyone have any experience with bending rods like this, and if so could you please share!
Thanks,
Mike
12 replies so far
View Loren's profile
4870 posts in 1814 days
#1 posted 213 days ago
You have to heat it if you want a tight bend. You can
take a couple of pipes and tap a hole in each one for a
set screw, then clamp the pipes to your rod with
perhaps 3” of rod exposed in the middle. Heat it red hot
with a torch if you want a tight bend. If you want
less tight bend you can do it cold. Clamp a 3/4” pipe
upright in your vise and use it as a fulcrum to pull the
pipe handles towards you.
There are lots of ways to do it. If you try to do it without
handles you’ll get a bulging affect near the bend. It
won’t look like a straight rod with a clean bend in it.
View ajosephg's profile
ajosephg
1718 posts in 1727 days
#2 posted 213 days ago
I think I would pay a visit to a guy that makes wrought iron fences and stuff.
-- Joe
View Gshepherd's profile
Gshepherd
1363 posts in 367 days
#3 posted 213 days ago
I bet a local machine shop could do it fairly reasonable was well….... A local welder could also do it….
-- What we do in life will Echo through Eternity........
View EdwardR's profile
EdwardR
52 posts in 420 days
#4 posted 213 days ago
Ditto on the local welding shop They will have the rod and the means to bend it. Most likely the best price option also.
View jap's profile
jap
1029 posts in 220 days
#5 posted 213 days ago
I’d do the same as loren
-- Joel -- http://diversitywoodworks.wordpress.com
View Viktor's profile
Viktor
467 posts in 1584 days
#6 posted 213 days ago
Give it to a1Jim, this is him doing it:
The radius of the bend will match his neck
If you need smaller radius thread the rod through two pieces of pipe, step on one and pull the other. With couple feet of leverage ½” rod will bend like butter (done that).
View David Kirtley's profile
David Kirtley
1250 posts in 1164 days
#7 posted 213 days ago
If you can’t find a welder, a muffler should should be able to as well if you don’t feel like cranking up a torch or even a BBQ pit with a little charcoal.
It doesn’t take a lot to bend 1/2” stock.
View teejk's profile
teejk
970 posts in 850 days
#8 posted 213 days ago
VA must have a ton of blacksmiths to handle the horse trade. if not, then I think time and a lot of MAAP gas with a vise will work (probably have to cool it from time to time so welder’s gloves/grippers are in order as well).
View renners's profile
renners
1878 posts in 1135 days
#9 posted 213 days ago
Depending on the radius you require, a pipe bender as used by plumbers will do this. I have seen 1/2” re-bars bent to make ground anchors using one. I thought at the time there’s no way that’ll do that, but it did and I was amazed.
No heat required. Got a mate who’s a plumber?
-- Do or do not, there is no try
View dhazelton's profile
dhazelton
828 posts in 462 days
#10 posted 213 days ago
Do you need the bend toward the end of the bar? Put it in a trailer hitch of a car or truck and start pulling out toward the side of the car. I watched guys bending rebar like that for inside a concrete footing.
View bondogaposis's profile
bondogaposis
1237 posts in 517 days
#11 posted 213 days ago
Heat it w/ MAP gas until cherry red, put in a mechanics vise and bend away. Easy.
-- Bondo Gaposis
View MrRon's profile
MrRon
1572 posts in 1409 days
#12 posted 212 days ago
Merchant grade steel bars (the ones found in big box stores), are not good enough quality to bend without breaking. Dependind on how sharp a bend, you can heat it up before bending. Hot rolled steel (black) rods will bend better than cold rolled steel (shiny) rods.
