| Forum topic by AJswoodshop | posted 215 days ago | 423 views | 0 times favorited | 9 replies | ![]() |
215 days ago |
Topic tags/keywords: router If your going to mount your router to a insert plate, do you mount your router to the plate with the screws that were in your router base plate? Thanks! -- If I can do it.....so can you! -AJswoodshop |
9 replies so far
#1 posted 215 days ago |
Hi AJ Edit -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 215 days ago |
Probably will need different screws -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#3 posted 215 days ago |
usually requires longer screws. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#4 posted 214 days ago |
Thanks guys fir the comments! I’ll post the router table in the projects when it’s done. -- If I can do it.....so can you! -AJswoodshop |
#5 posted 214 days ago |
+1 on all that’s been said…I’ll just add to insure you’re going to use the same type a screw size/thread. I just added a new router to my table and almost ruined the router base. At first glance it looked like it needed a #8-32 screw. It started, but then got tight. After closer inspection (under magnifying glass) noticed the threads were different. Broke out my calipers and the original screws in the router were metric. -- Nicky |
#6 posted 214 days ago |
I needed longer screws for mine. My plate is small enough that I can use it as a base out of the table for simple runs. I recently had to edge some 16’ long handrail pieces and sure was nice to just lift the router out and go without swapping to my base plate. -- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it. |
#7 posted 214 days ago |
AJ, like everyone said, you might need longer screws. Check the threads carefully so you get the right ones. Some might be metric on newer routers. -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! |
#8 posted 214 days ago |
Thanks Jim! I just completed all of the drawers today, it’s coming along! -- If I can do it.....so can you! -AJswoodshop |
#9 posted 214 days ago |
My plate came with longer screws for PC bases (it was also pre-drilled for a PC router). For the craftsman router I had, a trip to the hardware store with the base was in order. If you have to buy new screws, make sure they are flat top machine screws. Buy a nut for the screws also. You may have to trim them. Put the nut on the screw before you take a hack saw/cutoff wheel to them. After you cut, twist the nut off to clean the threads up. |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1528 |
3545 |
15759 |
Hand Tools
2033 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6154 |
